Installation & Licensing
Member
t_handl
Message 1 of 2 (321 Views)
Revit 2012 Install Issue
321 Views, 1 Replies
02-27-2013 06:09 AM
Tried to install Revit and am getting a error as soon as installation starts.  It shows fail on all three programs (Architecture, Review and Material Library.  Thought it might have downloaded wrong so downloaded and tried to install again to no avail.  Any suggestions.  This is the installation log file that pops up for review.
2013/2/26:20:09:44 travis HOME === Setup started on HOME by travis === 2013/2/26:20:09:44 travis HOME Launch 2013/2/26:20:09:48 travis HOME === Setup ended ===
2013/2/26:20:09:45 travis HOME === Setup started on HOME by travis === 2013/2/26:20:09:45 travis HOME Launch 2013/2/26:20:09:49 travis HOME PageOpen LaunchDialog   2013/2/26:20:10:43 travis HOME PageOpen LicenseDialog   2013/2/26:20:10:54 travis HOME PageOpen ProductInfoDialog   2013/2/26:20:11:24 travis HOME PageOpen ProductSelectionDialog2   2013/2/26:20:11:43 travis HOME PageOpen FullProgressDialog   2013/2/26:20:11:43 travis HOME Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\travis\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/2/26:20:12:00 travis HOME Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded  2013/2/26:20:12:00 travis HOME Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2013/2/26:20:12:16 travis HOME Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded  2013/2/26:20:12:16 travis HOME Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\travis\AppData\Local\Temp\vcredist_x86_2010.log 2013/2/26:20:12:18 travis HOME Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603 2013/2/26:20:12:19 travis HOME Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2013/2/26:20:12:19 travis HOME Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2013/2/26:20:12:19 travis HOME PageOpen InstallCompleteDialog   2013/2/26:20:13:01 travis HOME === Setup ended ===
2013/2/26:20:17:49 travis HOME === Setup started on HOME by travis === 2013/2/26:20:17:49 travis HOME Launch 2013/2/26:20:17:53 travis HOME === Setup ended ===
2013/2/26:20:17:49 travis HOME === Setup started on HOME by travis === 2013/2/26:20:17:49 travis HOME Launch 2013/2/26:20:17:52 travis HOME PageOpen LaunchDialog   2013/2/26:20:20:00 travis HOME PageOpen LicenseDialog   2013/2/26:20:20:06 travis HOME PageOpen ProductInfoDialog   2013/2/26:20:20:08 travis HOME PageOpen LicenseDialog   2013/2/26:20:22:42 travis HOME PageOpen ProductInfoDialog   2013/2/26:20:23:41 travis HOME PageOpen ProductSelectionDialog2   2013/2/26:20:24:20 travis HOME PageOpen FullProgressDialog   2013/2/26:20:24:20 travis HOME Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\travis\AppData\Local\Temp\vcredist_x86_2010.log 2013/2/26:20:24:23 travis HOME Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603 2013/2/26:20:24:23 travis HOME PageOpen InstallCompleteDialog   2013/2/26:20:28:27 travis HOME === Setup ended ===
2013/2/26:20:37:20 travis HOME === Setup started on HOME by travis === 2013/2/26:20:37:20 travis HOME Launch 2013/2/26:20:37:22 travis HOME === Setup ended ===
2013/2/26:20:37:21 travis HOME === Setup started on HOME by travis === 2013/2/26:20:37:21 travis HOME Launch 2013/2/26:20:37:22 travis HOME PageOpen LaunchDialog   2013/2/26:20:38:02 travis HOME PageOpen LicenseDialog   2013/2/26:20:38:07 travis HOME PageOpen ProductInfoDialog   2013/2/26:20:38:14 travis HOME PageOpen ProductSelectionDialog2   2013/2/26:20:38:25 travis HOME PageOpen FullProgressDialog   2013/2/26:20:38:25 travis HOME Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\travis\AppData\Local\Temp\vcredist_x86_2010.log 2013/2/26:20:38:27 travis HOME Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603 2013/2/26:20:38:27 travis HOME PageOpen InstallCompleteDialog   2013/2/26:20:44:34 travis HOME === Setup ended ===
2013/2/27:06:49:43 travis HOME === Setup started on HOME by travis === 2013/2/27:06:49:43 travis HOME Launch 2013/2/27:06:49:47 travis HOME === Setup ended ===
*Expert Elite*
TravisNave
Message 2 of 2 (301 Views)
Re: Revit 2012 Install Issue
02-27-2013 08:26 AM in reply to: t_handl
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
