Installation & Licensing
Revit 2012 Install Issue
2 REPLIES 2
2739 Views, 2 Replies
Tried to install Revit and am getting a error as soon as installation starts.  It shows fail on all three programs (Architecture, Review and Material Library.  Thought it might have downloaded wrong so downloaded and tried to install again to no avail.  Any suggestions.  This is the installation log file that pops up for review.
2013/2/26:20:09:44 travis HOME === Setup started on HOME by travis === 2013/2/26:20:09:44 travis HOME Launch 2013/2/26:20:09:48 travis HOME === Setup ended ===
2013/2/26:20:09:45 travis HOME === Setup started on HOME by travis === 2013/2/26:20:09:45 travis HOME Launch 2013/2/26:20:09:49 travis HOME PageOpen LaunchDialog   2013/2/26:20:10:43 travis HOME PageOpen LicenseDialog   2013/2/26:20:10:54 travis HOME PageOpen ProductInfoDialog   2013/2/26:20:11:24 travis HOME PageOpen ProductSelectionDialog2   2013/2/26:20:11:43 travis HOME PageOpen FullProgressDialog   2013/2/26:20:11:43 travis HOME Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\travis\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/2/26:20:12:00 travis HOME Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded  2013/2/26:20:12:00 travis HOME Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2013/2/26:20:12:16 travis HOME Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded  2013/2/26:20:12:16 travis HOME Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\travis\AppData\Local\Temp\vcredist_x86_2010.log 2013/2/26:20:12:18 travis HOME Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603 2013/2/26:20:12:19 travis HOME Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2013/2/26:20:12:19 travis HOME Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2013/2/26:20:12:19 travis HOME PageOpen InstallCompleteDialog   2013/2/26:20:13:01 travis HOME === Setup ended ===
2013/2/26:20:17:49 travis HOME === Setup started on HOME by travis === 2013/2/26:20:17:49 travis HOME Launch 2013/2/26:20:17:53 travis HOME === Setup ended ===
2013/2/26:20:17:49 travis HOME === Setup started on HOME by travis === 2013/2/26:20:17:49 travis HOME Launch 2013/2/26:20:17:52 travis HOME PageOpen LaunchDialog   2013/2/26:20:20:00 travis HOME PageOpen LicenseDialog   2013/2/26:20:20:06 travis HOME PageOpen ProductInfoDialog   2013/2/26:20:20:08 travis HOME PageOpen LicenseDialog   2013/2/26:20:22:42 travis HOME PageOpen ProductInfoDialog   2013/2/26:20:23:41 travis HOME PageOpen ProductSelectionDialog2   2013/2/26:20:24:20 travis HOME PageOpen FullProgressDialog   2013/2/26:20:24:20 travis HOME Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\travis\AppData\Local\Temp\vcredist_x86_2010.log 2013/2/26:20:24:23 travis HOME Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603 2013/2/26:20:24:23 travis HOME PageOpen InstallCompleteDialog   2013/2/26:20:28:27 travis HOME === Setup ended ===
2013/2/26:20:37:20 travis HOME === Setup started on HOME by travis === 2013/2/26:20:37:20 travis HOME Launch 2013/2/26:20:37:22 travis HOME === Setup ended ===
2013/2/26:20:37:21 travis HOME === Setup started on HOME by travis === 2013/2/26:20:37:21 travis HOME Launch 2013/2/26:20:37:22 travis HOME PageOpen LaunchDialog   2013/2/26:20:38:02 travis HOME PageOpen LicenseDialog   2013/2/26:20:38:07 travis HOME PageOpen ProductInfoDialog   2013/2/26:20:38:14 travis HOME PageOpen ProductSelectionDialog2   2013/2/26:20:38:25 travis HOME PageOpen FullProgressDialog   2013/2/26:20:38:25 travis HOME Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\travis\AppData\Local\Temp\vcredist_x86_2010.log 2013/2/26:20:38:27 travis HOME Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603 2013/2/26:20:38:27 travis HOME PageOpen InstallCompleteDialog   2013/2/26:20:44:34 travis HOME === Setup ended ===
2013/2/27:06:49:43 travis HOME === Setup started on HOME by travis === 2013/2/27:06:49:43 travis HOME Launch 2013/2/27:06:49:47 travis HOME === Setup ended ===
2 REPLIES 2
TravisNave
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
in reply to: TravisNave
thanks a lot!!!!!!
Administrator Productivity
