Revit 2012 installation fails at this point every time. Can you help?
2011/5/13:15:05:29 Randal RANDAL-PC === Setup started on RANDAL-PC by Randal ===
2011/5/13:15:05:29 Randal RANDAL-PC Launch
2011/5/13:15:06:35 Randal RANDAL-PC PageOpen LaunchDialog
2011/5/13:15:07:30 Randal RANDAL-PC PageOpen LicenseDialog
2011/5/13:15:07:37 Randal RANDAL-PC PageOpen ProductInfoDialog
2011/5/13:15:08:22 Randal RANDAL-PC PageOpen ProductSelectionDialog2
2011/5/13:15:08:34 Randal RANDAL-PC PageOpen FullProgressDialog
2011/5/13:15:08:34 Randal RANDAL-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/5/13:15:08:38 Randal RANDAL-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2011/5/13:15:08:38 Randal RANDAL-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/5/13:15:08:43 Randal RANDAL-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2011/5/13:15:08:43 Randal RANDAL-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/5/13:15:08:45 Randal RANDAL-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2011/5/13:15:08:45 Randal RANDAL-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/5/13:15:08:47 Randal RANDAL-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2011/5/13:15:08:47 Randal RANDAL-PC Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2011/5/13:15:10:15 Randal RANDAL-PC Install DirectX® Runtime Succeeded
2011/5/13:15:10:15 Randal RANDAL-PC Installing Microsoft VSTA Dependencies (x64) - ENU: E:\3rdParty\x64\VSTA\expdbgsetup.exe /q
2011/5/13:15:10:24 Randal RANDAL-PC Install Microsoft VSTA Dependencies (x64) - ENU Succeeded
2011/5/13:15:10:24 Randal RANDAL-PC Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="E:\x64\en-us\RAC2012\RAC2012.mst;C:\Users\Randal\AppData\Local\Temp\_AI8065.tmp\x64\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/5/13:15:11:12 Randal RANDAL-PC Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
2011/5/13:15:11:12 Randal RANDAL-PC Rollback Microsoft VSTA Dependencies (x64) - ENU Failed Failure is ignored, Result=1619
2011/5/13:15:11:12 Randal RANDAL-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2011/5/13:15:11:13 Randal RANDAL-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2011/5/13:15:11:15 Randal RANDAL-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2011/5/13:15:11:16 Randal RANDAL-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2011/5/13:15:11:17 Randal RANDAL-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
You're gonna have to zip and attach the bigger install .log file from your %TEMP% location to be of any help.
pdf file attached. I tried installing from another disk and also a download. Failed each time. Revit 2011 installed without any trouble and I have used it sucessfully for many months. The computer is a Toshiba Qosmio laptop, I7, 8G Ram with Windows 7 Pro and Revit installed on the solid state drive.
That's still not the more specific product installation log. The other log will have more detailed information about the error.
