Installation & Licensing
New Member
paelio
Message 1 of 3 (905 Views)
Revit 2011 crashes after splash screen
905 Views, 2 Replies
05-19-2010 09:51 AM
Hi all,
Hoping you can help with this issue. We have recently installed Revit 2011 on 4 machines. On one of the machines, when Revit is started it gives a general error "Autodesk Revit has encountered a problem and needs to close. We are sorry for this inconvenience." The error pops up after the splash screen, when the actual program window starts to load.
I have tried to repair the install- didnt help. Reinstalled twice- no luck.
This machine is only month's old running win xp 32bit with an i3 processor, 4gb ram installed, with a quadro fx 1500 gpu. It had no issues running Revit 2010. The other 3 machines that run without issue are all 3 years old, using both 32bit and 64bit win xp, also with 4gb ram installed with quadro fx 1500.
The program is licensed; the transfer utility lists it as ready for export. Users also have admin rights to local drives. All 4 installs are stand alone licenses.
I came accross a thread regarding the arcvision content manager causing errors; we do not use any content outside of what is installed with Revit. I looked at the revit.ini files of all 4 machines, and the lines relating to ACMSettings do not appear in any of the files, although the the ip address and port are correct in the 3 working machines.
I tried replacing the .ini file with one from another working machine, that also did not help. I'm running out of theories. Any other ideas out there? Any help is much appreciated. Edited by: paelio on May 19, 2010 5:05 PM
Product Support
Antonio_Barroca
Message 2 of 3 (904 Views)
Re: Revit 2011 crashes after splash screen
05-26-2010 01:23 AM in reply to: paelio
This problem can be due to several factors. The most common are:
• Corrupted user profile. To solve this problem, create a new user profile in Windows, log in with this new user and try running the product.
• .NET Framework 3.5 corruption. This component is corrupted and originates this problem. To solve it, download and install the last version of the .NET Framework 3.51 SP1 from the Microsoft web site. http://www.microsoft.com/downloads/details.aspx?familyid=ab99342f-5d1a-413d-8319-81da479ab0d7&displaylang=en
Regards
Antonio Barroca
Autodesk Product Support
We appreciate your quick feedback on this forum!
Regards
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Antonio Barroca
Product Support Specialist
New Member
pokeitwithastick
Message 3 of 3 (191 Views)
11-10-2011 06:59 AM in reply to: Antonio_Barroca
So now that we know there's a problem wit the user profile how do I fix it without having to re-create all of the other settings associated with this profile?
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
