I have tried installing both Revit Architecture 2010 and 2011 multiple times, but they both lock-up/freeze when it gets to the "recent files" screen.
When I try clicking on anything in the Revit window it just makes the default windows warning/alert chime.
My system:
Windows 7 Ultimate
AMD Phenom 9850 Quad-Core 2.51GHz
4 GB RAM
ATI HD4870 1Gig
Any ideas on how to get Revit to work?
Mark Lipsinic
Solved by marklip. Go to Solution.
hi Marklip
Try ro go to your Revit.ini file (copy it so you have a backup)
should be somewhere like \Program Files\Autodesk Revit Architecture 2010\Program\Revit.ini
Edit the file in notepad
Finde [Recent File List] and [Recent Workset List] in the file and delete all between .. save and restart Revit
Hi KEA,
I looked at the revit.ini file like you said, but there was no line like [Recent Workset List]. I'm assuming it is because I haven't even been able to to get Revit to open initially. I haven't even been able to activate any of the installations of Revit because it just freezes before it gets that far.
I even tried adding the line "DisplayRecentFilesPage=0", but that didn't even help.
Mark
did you install all the updates for revit 2010/2011?
make sure you have the latest video card driver for your machine
DarrenP
I had a feeling that there was something about my Windows 7 installation that was corrupted, so I reinstalled Windows 7 and Revit.
It's working now. 😛
