I am hoping someone in the community has had a similar experience, and can help with this. First of all, this is only happening on 64 bit installations - 32 bit is fine.
The problem is two-fold. First, we go to install Revit Structure 2011 from a disc that we have. We double click on setup.exe, and nothing happens. The program will not install. Now this is the really puzzling aftermath: after this occurrence we are only able to install *.msi files - no executables will install! No drivers, no extensions, no programs, unless we can locate an msi installer! At present, the only way we have found to fix this issue, is to re-image and rebuild the machine. Does anyone have any thoughts on this?
As far as future installs are concerned, I assume we should attempt to download a clean copy, unless anyone knows if the problem is more widespread.
Any help will be greatly appreciated.
-W. Krones
URS, Washington, DC
Thanks. FYI, there was no anti-virus running during the install. Also, I don't think the association is completely broken, because it is only setup.exe that won't work. "zip". exe will function, for example.
