My machine crashed and I am trying to restore from a Time Machine backup. AutoCAD LT 2013 for Mac will not restore. I received an error and instructions to open terminal, rename folder, etc. The FLEXnet folder does not exist in my library so I was unable to rename it. Tried to re-download software. When I
click on AutoCAD_LT_2013_English_Mac_OSX link I receive an error "File does not exist." Have tried the LTU as described in the forum but it does nothing. Can anyone help?
Hello and Welcome to the community.
To resolve your issue please try the following solutions listed in the link.
Reset Standalone licensing on the Mac [Time Machine]
http://upandready.typepad.com/up_and_ready/2013/02/reset-standalone-licensing-on-the-mac.html
The reply/solution doesn't work unless you can find that folder. I don't have the folder either, and I've just restored from Time Machine. So - same problem. I cannot open Autocad now.
Tim.Haggerty - did you ever find a solution for this?
I would try the following:
Uninstall the program. Delete the Autodesk folders from these locations
Library/Preferences/
Library/Autodesk
Library/Application Support/Autodesk/
Delete the TSF file from the above post as well.
Then reinstall and see if it helps.
Thank you for taking part in our community!
