Installation & Licensing
jlaidler
15233 Views, 5 Replies
Reread server failed
We have AutoCAD 2005 (Network).
Everything was working fine, until we had a power outage.
Now after re-starting the license manager, the license no longer works. Attached is a screenshot after I did a Status Enquiry.
Thanks.
5 REPLIES 5
jlaidler
in reply to: jlaidler
Server is now running... after selecting Start Server, I had to wait about 3 minutes before selecting Reread License File.
Another thing you might try is to go into LMTOOLS, Select the "Config Services" tab and make sure that "use services is checked and this will make the "start server at power up" active, toggle that on and you should not have any further problems on a system reboot. Mike Gauvin Director Tech Services CADsoft Consulting "jclaidler" wrote in message news:14051979.1082382920726.JavaMail.jive@jiveforum1... > Server is now running... after selecting Start Server, I had to wait about 3 minutes before selecting Reread License File.
jlaidler
I did just that.... thanks for the help.
license
in reply to: license
not quite sure why your resurrecting a thread from 17 years ago with a solution no need for this
Administrator Productivity
