• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Request codes keep changing - Autocad 2008 & Windows 7x64
    297 Views, 2 Replies
    12-05-2012 06:45 AM
    I had no problems running Autocad 2008 on Windows 7 for almost 2 years then about 3 months ago I got an activation error and I was forced to call support to get an activation code. I believed at the time it was due to a new SSD I had installed but I just had it happen again yesterday and I've had no hardware changes. I went through chat to get new activation codes yesterday....all was fine and then this morning it happened again. Each time the code is different. The rep yesterday suggested compatibility mode so I set it to run in Vista compatibility mode but that didn't work.
    I checked in my Windows Events logs and I do see a controller error Event ID 11 -source "atapi"  "The driver detected a controller error on \Device\Ide\IdePort8" and I wonder if it could be related.
    Any help would be appreciated. It's going to let me run it for 7 days so hopefully I can figure this out before I get another set of activation codes.
    Please use plain text.
    Product Support
    Re: Request codes keep changing - Autocad 2008 & Windows 7x64
    12-05-2012 07:01 AM in reply to: Lantec62
    I would try the following:
    http://usa.autodesk.com/getdoc/id=DL5620053
    I suspect that it maybe the SSD drive.
    http://forums.autodesk.com/t5/AutoCAD-2008/Autocad-2008-request-code-changes-after-activation-of-pro...
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    New Member
    12-05-2012 07:43 AM in reply to: david.lau
    You may be right....as my OS dirve, the SSD (OCZ Octane S2) kept giving me MBR errors when I first got it so I had relagated it to data storage only. My SSD was the only drive on the RAID controller. I ran the fix and then thought better of it and I have pulled the SSD for good.
    I checked my Autocad installation and it is still using the same request code as earlier this morning. Is there a way to force it to update that code before I get with Adesk chat to reactivate?
