• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Reinstalling 2009 Revit Architectural Suite
    75 Views, 1 Replies
    01-17-2013 02:54 PM
    Several months ago my computer crashed and I had to have it reformated. I started re-installing all my programs. When I got to to reinstalling RAS, I couldn't get the usual go ahead to use it. I was told that it was because that it is not supported anymore being 2009. Why is that? Can't we still use a program (that you buy for several thousand dollars) even though it is not supported?
       Ray
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Reinstalling 2009 Revit Architectural Suite
    01-17-2013 03:08 PM in reply to: rfrisch
    Depends on the context.
    If it was 2009 under Subscription then the lease on that product has expired under normal Subscription upgrades.  For example, current Subscription for 2013 products will allow you to run licensed versions back to 2010.  Thus 2009 has expired.  In a few months, 2014 Subscription will expired 2010 products.  Once that happens, you can no longer activate the license on that product.  Only licenses that have not been upgraded or crossgraded (or under Subscription) maintain their last valid lease.  So if you only purchased 2009 and never upgraded it or it was the last update prior to lapse of Subscription, you can activate it.  Otherwise, it is expired.
    If it is in the context of compatibility, 2009 is not compatible with Windows 7 or Windows 8.  You would have to use Windows XP or Vista to run 2009 products, assuming it has not expired under Subscription.
    If it is in the context of filetype, the product is not backwards compatible.  So doing any work in later versions will not give you any advantage in running 2009 if you have already migrated to a newer version.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
