I have to try to deinstall Revit 2012.
When I do this I was getting an error that reinstall not was posible.
Then I delete Revit by self including from the Registry.
When i try now to install Revit, then I get an report that Revit already was installed.
Has anyone already experienced this?
Hi f.renes,
Have a look at this solution which explain the best way to remove our products from a Windows system.
Thanks!
If the above solution didn't help in uinstalling Revit.
Please try the tool from Microsoft.
http://support.microsoft.com/mats/Program_Install_and_Uninstall
If it doesn't help, please post the exact error message when uninstalling.
Thank you for your reaction but we found the problem.
There was a line in the registry that referred to RAC2012.
We have removed this line and then we could install Revit again.
In any case, thanks for now.
FNJ RENES
UMC Utrecht
Holland
