Installation & Licensing
Reinstall Revit Structureask for Disk
4 REPLIES 4
884 Views, 4 Replies
I want to Reinstall Revit Structure 2013
it gives
Please insert Insert Disc: Revit Structure 2013
The program is DOWNLOADED
Where can I give a path ???
4 REPLIES 4
TravisNave
Did you download the entire suite?
Autodesk Forums:
emily.xu
If your download is more than one part, then try to copy all the contents into one folder and then install.
If no, I thinks maybe it's your download uncompleted or corrupted, please redownload using another method, such as Browser download.
Hope that helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
in reply to: emily.xu
i go uninstall the program
but the problem with that there is no auto remove license
TravisNave
It is not necessary to remove the license.
Autodesk Forums:
Administrator Productivity
