Installation & Licensing
Regarding installation of Autocad 2004
1 REPLY 1
Concerned
3167 Views, 1 Reply
Hi guys, I tried searching around but I find no problems similar to mind, so apologies if I am mistaken. I am trying to install Autocad 2004 in Windows 7 64 bit, but halfway through the installation will produce an error (See attachment). I was wondering if anybody know what is the problem; google search yields many website hosting suspicious links and the few legitimate ones are at a dead end too.
Thank you for your time.
1 REPLY 1
TravisNave
in reply to: Concerned
AutoCAD 2004 is a retired 32-bit application and is not supported on Windows 7 64-bit.  Only Autodesk 2010 products and newer are supported.  You should consider running Windows XP Mode on your Windows 7 workstation if the lease on your AutoCAD 2004 is still valid.  Good Luck!
http://www.microsoft.com/windows/virtual-pc/download.aspx
Autodesk Forums:
Administrator Productivity
