Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
: Regarding Case 07132619 - EReg Customer Service Request for xxx-xxxxxx xx
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am having issues relating to running autocad v12 or Autocad v13. The packages are available for employee install from a liscense server. When I do the install it goes without problems but when I attempt to launch, I get error messages with either improper serial number and product data or liscense not found.
Edited by
Discussion_Admin
Re: : Regarding Case 07132619 - EReg Customer Service Request for xxx-xxxxxx xx
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
can you provide any screen shots?
was the product installed as a network license?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Was the deployment created properly and are you installing via the shortcut link created in the root of the shared folder? If you're drilling down into the AdminImage subfolder looking for a setup or .msi file, then you're installing it incorrectly.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: : Regarding Case 07132619 - EReg Customer Service Request for xxx-xxxxxx xx
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The product was installed originally from a liscense server and it aborted when attempting to open a .msi file on the inventorFusion directory, so I downloaded from the Autodesk downloads, It loads successfully but looks for the liscense info to go beyond the 30 day trial.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you installed it as a trial, that means it is a stand-alone activation. You will have to uninstall the product and reinstall it as a network version and point it to your license manager during the install setup.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When I installed off of the autodesk site, this was my error.
Edited by
Discussion_Admin
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please note that this is an open forum and you should guard against posting your serial number.
Discussion_Admin
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
looks like your trying to activate it as a standalone license which is not correct
you need to uninstall the product and reinstall it as a network license
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi neil.norat:
I checked on your serial number and if you can provide me your host ID and server name, I'd be able to generate a license file fo you. I will re-open Case 07132619 and communicate with you from there.
