• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Chadarak07
    Receiving this error upon installation 0x659 internal error. What is fix?
    62 Views, 1 Replies
    02-08-2012 12:30 PM
    Receiving this error upon installation 0x659 internal error. What is the fix?
    I have completely removed anything Autodesk related. But I still get this error. Has anyone else had this?
    ***Guru
    TravisNave
    Re: Receiving this error upon installation 0x659 internal error. What is fix?
    02-09-2012 07:50 AM in reply to: Chadarak07
    The 0x659 error means that the installation is forbidden by system policy.  It could mean that you do not have enough rights to install the program.  It could also be due to a restrictive anti-virus program.
    Make sure that you do not have any other version of Design Review installed. If so, uninstall it first.  And make sure you are installing with local admin rights with anti-virus and any other security software disabled.
    You might consider downloading and installing the latest Design Review if you cannot get your version to work:
    http://usa.autodesk.com/design-review/
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
