Installation & Licensing
ReCap failed Installation, Result=1638
4 REPLIES 4
tijmen
1778 Views, 4 Replies
I'm having trouble with installation of Recap in Building Suite 2014. Unfortunately it doesn't show an link to the log file. I've retrieved it myself and is says the following. It seems there is anissue with the Language Pack.... I can't find a topic on this forum about this issue. Please help.
2014/3/10:16:50:11 tijmen WAM-USR-HP Installing Autodesk® ReCap: TRANSFORMS="C:\Autodesk\Building_Design_Suite_Premium_2014_English_Win_32_64bit_dlm\x64\en-us\RC2014\AutodeskReCap.mst;C:\Users\tijmen\AppData\Local\Temp\_AI3E1A.tmp\x64\RC2014\AutodeskReCap-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Premium_2014_English_Win_32_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:16:50:54 tijmen WAM-USR-HP Install Autodesk® ReCap Succeeded
2014/3/10:16:50:54 tijmen WAM-USR-HP Installing Autodesk® ReCap Language Pack: TRANSFORMS="C:\Users\tijmen\AppData\Local\Temp\_AI3E1A.tmp\_la9BEB.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Building Design Suite Premium 2014" SETUP_PACKAGECODE={D7E74739-DCD0-48e4-86A5-6203809C3639} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Premium_2014_English_Win_32_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:16:50:55 tijmen WAM-USR-HP Install Autodesk® ReCap Language Pack Failed Installation aborted, Result=1638
2014/3/10:16:51:05 tijmen WAM-USR-HP Rollback Autodesk® ReCap Succeeded
4 REPLIES 4
jessica.t
in reply to: tijmen
Hi Tijmen!
You can download Autodesk Recap separately from the product trial page if you can't get it to completely download from the suite. Please let me know if this resolves your issue. Thanks!
Jessica Thrasher
tijmen
in reply to: tijmen
What do you know? It worked, thank you.
jessica.t
in reply to: tijmen
Great news! You're welcome Smiley Happy
Jessica Thrasher
eromeropaya
in reply to: jessica.t
I have the same problem, or similar with the Revit 2015 Spanish version (Autodesk_Revit_2015_Spanish_Win_64bit_R2_dlm.sfx)....i´ve posted it 5 minutes ago on a new post. please read it an if you can, help me.
THXS.
Administrator Productivity
