I had computer problems tonight and I have to do clean installation of Windows 7. How do I re-install AIM? I have 24 days left in the trial version of AIM. Will there be student version of AIM?
Relax Jeff. I can only assume by your vague acronym that you want Autodesk Infrastructure Modeler. You can find that trial download here.
http://usa.autodesk.com/adsk/servlet/download/item?siteID=123112&id=17193264
I was not able to install AIM because my computer rebooted itself after running the setup program. I wish that there's a student version of AIM. I was able to install student versions of AutoCAD 2012 and 3DS MAX 2012. I don't have a real job and I work in the woodworking shop at a program for mentally handicapped people. Is it true that Autodesk products modify the MBR when they are installed? I found this out while checking the Autodesk forums.
Yes, it does that so you can only run a trial once per machine.
