Hi douglas,
I wanna to change deny to allow acccording to your previous post, but when I enter the file the change was already there and I can't install Vault server anyway.
Any idea please
thanks
Regards
Joel
There are lots of specifics that could account for this error. Can you please upload the specific error messages to get? Each has its own resolution.
Hi Douglas,
I will sent my error message after I will reboot my server today, because I try to install Vault and it need a reboot. Also The error message is in french, I will translate it for you.
many thanks for your help
Regards
Joel
Having the same issues trying to install vault collaboration server which I gave up on now trying to reinstall vault server Professional. Errors when it gets to installing the english language pack. Here's what my dialog box says:
Autodesk Vault Professional 2011 (Server)
Error 29001. Vault management error:
System.Web.Services.Protocols.SoapException: 215 --->
Connectivity.Core.Exceptions.CoreException: InvalidSystemDbLogin
[215]
Server stack trace:
at
Connectivity.Core.Database.TransactionContext.OnSqlException(SqlException e)
at
Connectivity.Core.Database.TransactionContext..ctor(TransactionDatabase A_0, DatabaseUser A_1, Boolean A_2)
at
Connectivity.Core.Database.TransactionBase.SetupTransactionContext(TransactionReqs transactionReqs, TransactionDatabase database, Nullable`1 databaseUser)
at
Connectivity.Core.DataAccess.LegacySystems.a..ctor(TransactionReqs A_0)
at
Connectivity.Core.Services.KnowledgeMasterService.UpdateSQLLogins()
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Exception rethrown at [0]:
at
System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at
System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at
at
Connectivity.Web.Services.KnowledgeVaultService.UpdateDatabaseLogins(String dbUser, String dbPassword)
--- End of inner exception stack trace ---
at
Have already tried the Allow/Deny thing which was already set to Allow.
Windows Vista 32bit
3GB RAM
nVidia Quadro FX580
Have Previously installed Server with updates 1 and 2
Erik Kurek
Autodesk Inventor Certified Professional
Hi mcadae,
What I did is that I install Vault 2011 on another PC instead on our server and it work. No problem at all during the installion.
I tried to install it on our server 2008 standard without success. So until Autodesk found a real solution about this problem, it will stay on that PC.
Regards
Joe
