Installation & Licensing
Re-Installation Problems
5 REPLIES 5
andy.beckett123
658 Views, 5 Replies
I uninstalled Autodesk Inventor 2011 a while ago (I have Windows 7), and I have been trying to re-install it in the last couple of days.
I downloaded the zip files, used the Self-Ectracting archive, then got onto the installation wizard.
When I get to the "Select the Products to Install" page, Autodesk Inventor 2011, AutoCAD Mechanical 2011, Autodesk Vault (Client) and Autodesk Design Review 2011 are greyed-out and the boxes cannot be checked. I can only install Content Centre Libraries and Autodesk Material Library 2011 Medium Image Library.
Attached screenshot below.
Does anyone know how I can re-install Inventor 2011?
Thanks.
5 REPLIES 5
Your computer still thinks Inventor is installed.
Installation problems may be resolved using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
You should try the clean-uninstall first as you have Windows 7.  Please use the MSICUU2 at your own risk.
Autodesk Forums:
Thanks, TravisNave, I'll try your suggestions.
OK, that fixed my original problem, but now I have another:
I get an error message halfway through installation:
Error 1402. Could not open key.
 Full error message screenshot attached
Can anything be done?
Thanks again.
Bump
Administrator Productivity
