• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    Raster Network 2012 unable to obtain license with infrastructure suite
    311 Views, 12 Replies
    02-09-2012 05:16 PM
    Any ideas? HAve it working on others. New pc install. Must be forgetting something.
    Todd
    Please use plain text.
    TravisNave
    Re: Raster Network 2012 unable to obtain license with infrastructure suite
    02-10-2012 10:45 AM in reply to: tworzella
    What error are you getting?  Do your other network licensed products work?
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    DarrenP
    02-10-2012 11:18 AM in reply to: TravisNave
    are you talking about raster design?
    Product Support
    02-13-2012 08:53 AM in reply to: tworzella
    AutoCAD Raster Design 2012 network license doesn’t cascade into Autodesk Infrastructure Design Suite and is not included in the suite.
    Avto Chachava
    Autodesk Product Support
    Product Support
    02-14-2012 07:30 AM in reply to: avto
    Here is another tidbit of information:
    http://upandready.typepad.com/up_and_ready/2011/09/raster-design-2012-standalone-and-network-licensi...
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    Active Member
    02-14-2012 08:09 AM in reply to: TravisNave
    No License Found
    Active Member
    02-14-2012 08:09 AM in reply to: DarrenP
    yes
    Active Member
    02-14-2012 08:10 AM in reply to: david.lau
    all software is network versions
    DarrenP
    02-14-2012 08:12 AM in reply to: tworzella
    what product doesn't work?
    you need to provide more info
    Active Member
    02-14-2012 08:12 AM in reply to: avto
    HAve 2 seats of network infrastructure network, 6 seats of Civil 3d network, and 1 seat of Raster Design Network. I am setting up new pc. This configuration is working on other pc, not sure why it is not now. Will try uninstalling and re-installing RD and see what happens.
