• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Employee
    Re: REVIT WON'T INSTALL
    08-16-2012 07:31 AM in reply to: alex
    Alex,
    By updating the installer, Travis is probably refering to the Microsoft Installer. The Revit setup.exe will update the installer if needed, so I wouldn't worry to much about this one.
    When installing and it appears to hang at the Preparing Content, this is because it is downloading content in the background and depending on the content you choose to install and your internet connection this can take a long time.
    Make sure things like the Adobe Updater, AntiVirus updates and Windows Update aren't trying to install updates before starting the Revit install, if these aren't running you should be able to install without any problems.
    Danny
    Danny Hubbard
    QA Analyst
    Please use plain text.
    Valued Contributor
    alex
    08-16-2012 09:06 AM in reply to: alex
    when installing i will see adobe and windows update messages in the lower right corner. i disabled them and now my cpu shows 14-16% activity where before it showed 2-4% activity. maybe it is working now and i will wait it out.
    thanks, alex
    TravisNave
    08-16-2012 10:49 AM in reply to: alex
    Sounds promising.  The Revit installer has known to take over 12 hours to complete in some instances, so have patience if it seems stuck.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Valued Contributor
    alex
    10-12-2012 07:18 AM in reply to: DannyHubbard
    Hi Danny, I recently went back to try and install revit (2013 student version) and per this thread unplugged my internet connection and it installed with no content. when it comes up there are no elevation views and no rte files.
    I have tried diableing various things per instructions in this thread and did a file update install to put the content in.
    the acad system service or process would show it working making disk writes but even after 2 days it would not finish.
    I currently have the IDS premium subscription and do civil design work and would like to learn revit (outside my area of expertise) in my free time and eventually upgrade to IDS ultimate when i get it down and can produce a product with it.
    Any more ideas on how to get it installed propperly would be greatly appreciated.
    thanks, alex
    Valued Contributor
    alex
    10-14-2012 05:52 AM in reply to: DannyHubbard
    fyi, finally solved the installation problem. in one of the threads where is says add *.autodesk to trusted sites you have to disable the wps option too which i found in another post.
    Member
    12-25-2012 12:57 PM in reply to: DannyHubbard
    How lame is it that the install can't just show a progress bar for the download...
    Why don't we have the option anymore to download this content manually?
    New Member
    01-11-2013 01:07 AM in reply to: alex
    I can't get Revit to install on D disc. It keeps warning me that I don't have enough free space on C disc and when I select D disc, path just changes back to C disc. Any suggestions?
    DarrenP
    01-11-2013 05:28 AM in reply to: dora11
    it has to install files to the C drive
    this is how windows works
    start cleaning up your c dirve
    New Member
    03-03-2013 05:37 PM in reply to: alex
    i am having similar issues where is get the three red Xs next to the files im trying to install...please help...homework due tonight!:smileysad:Capture2.PNG
    TravisNave
    03-04-2013 09:10 AM in reply to: gaynors
    Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
    For more information about this process, please see my KB link here:
    http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
    Probably shouldn't have waited until the last minute for your homework!  Good Luck!
    Travis Nave
