Installation & Licensing
Employee
DannyHubbard
Message 11 of 23 (2,356 Views)
Re: REVIT WON'T INSTALL
08-16-2012 07:31 AM in reply to: alex
Alex,
By updating the installer, Travis is probably refering to the Microsoft Installer. The Revit setup.exe will update the installer if needed, so I wouldn't worry to much about this one.
When installing and it appears to hang at the Preparing Content, this is because it is downloading content in the background and depending on the content you choose to install and your internet connection this can take a long time.
Make sure things like the Adobe Updater, AntiVirus updates and Windows Update aren't trying to install updates before starting the Revit install, if these aren't running you should be able to install without any problems.
Danny
Danny Hubbard
QA Analyst
Valued Contributor
alex
Message 12 of 23 (2,354 Views)
08-16-2012 09:06 AM in reply to: alex
when installing i will see adobe and windows update messages in the lower right corner. i disabled them and now my cpu shows 14-16% activity where before it showed 2-4% activity. maybe it is working now and i will wait it out.
thanks, alex
TravisNave
Message 13 of 23 (2,347 Views)
08-16-2012 10:49 AM in reply to: alex
Sounds promising.  The Revit installer has known to take over 12 hours to complete in some instances, so have patience if it seems stuck.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Valued Contributor
alex
Message 14 of 23 (2,254 Views)
10-12-2012 07:18 AM in reply to: DannyHubbard
Hi Danny, I recently went back to try and install revit (2013 student version) and per this thread unplugged my internet connection and it installed with no content. when it comes up there are no elevation views and no rte files.
I have tried diableing various things per instructions in this thread and did a file update install to put the content in.
the acad system service or process would show it working making disk writes but even after 2 days it would not finish.
I currently have the IDS premium subscription and do civil design work and would like to learn revit (outside my area of expertise) in my free time and eventually upgrade to IDS ultimate when i get it down and can produce a product with it.
Any more ideas on how to get it installed propperly would be greatly appreciated.
thanks, alex
Valued Contributor
alex
Message 15 of 23 (2,235 Views)
10-14-2012 05:52 AM in reply to: DannyHubbard
fyi, finally solved the installation problem. in one of the threads where is says add *.autodesk to trusted sites you have to disable the wps option too which i found in another post.
Member
tcsandfort
Message 16 of 23 (2,038 Views)
12-25-2012 12:57 PM in reply to: DannyHubbard
How lame is it that the install can't just show a progress bar for the download...
Why don't we have the option anymore to download this content manually?
New Member
dora11
Message 17 of 23 (1,966 Views)
01-11-2013 01:07 AM in reply to: alex
I can't get Revit to install on D disc. It keeps warning me that I don't have enough free space on C disc and when I select D disc, path just changes back to C disc. Any suggestions?
DarrenP
Message 18 of 23 (1,960 Views)
01-11-2013 05:28 AM in reply to: dora11
it has to install files to the C drive
this is how windows works
start cleaning up your c dirve
New Member
gaynors
Message 19 of 23 (1,730 Views)
03-03-2013 05:37 PM in reply to: alex
i am having similar issues where is get the three red Xs next to the files im trying to install...please help...homework due tonight!:smileysad:Capture2.PNG
TravisNave
Message 20 of 23 (1,683 Views)
03-04-2013 09:10 AM in reply to: gaynors
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Probably shouldn't have waited until the last minute for your homework!  Good Luck!
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
