We've got a single license manager server, and have activated keys for the EMS_2014 Suite installed.
"86112EMS_2014_0F" v1.000, vendor: adskflex
License server: e143autocadlm
floating license starts: 1-jan-1990, expires: 15-jul-2016
Requests from the same USER/HOST do not consume a new license
This license can be checked out
Users of 86112EMS_2014_0F: (Total of 125 licenses issued; Total of 0 licenses in use)
AutoCAD 2014 Runs and gets licenses from it
Inventor 2013 Runs and gets licenses from it
Revit Architecture 2014 gives an error of 0.0.0 no license obtained.
We've tried Revit Architecture 2014 with the product code of 240F1 and 241F1 both do the same thing. Where do I go from here?
according to this http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21379174&linkID=9242018&CMP=OTC-RSS...
revit architecture 2014 doesn't grab an Education Master Suite 2014 license only revit one box does
DarrenP
Having the same issue. Is everyone having this issue rolling back to 2013 and getting a 2013 license?
Well here is the problem though, for licenses we have the following.
Autodesk 3ds Max Design 2014 (English) 64-Bit
Autodesk AutoCAD 2014 (English) 32-Bit
Autodesk AutoCAD 2014 (English) 64-Bit
Autodesk AutoCAD Architecture 2014 (English) 32-Bit
Autodesk AutoCAD Architecture 2014 (English) 64-Bit
Autodesk AutoCAD Civil 3D 2014 (English) 64-Bit
Autodesk AutoCAD Mechanical 2014 (English) 32-Bit
Autodesk AutoCAD Mechanical 2014 (English) 64-Bit
Autodesk InfraWorks 2014 (English) 64-Bit
Autodesk Inventor Professional 2014 (English) 32-Bit
Autodesk Inventor Professional 2014 (English) 64-Bit
Autodesk Revit Architecture 2014 (English) 32/64-Bit
Autodesk Showcase 2014 (English) 32-Bit
Autodesk Showcase 2014 (English) 64-Bit
xxx-xxxxxx 125
So what product code should I be using to get that version of Revit to run? It is supposed to be part of the Education Master Suite we have.
it could be a bug with the Educational Master Suite 2014
i would contact your educational license supplier and have them create a case with autodesk
DarrenP
Also, for some of the products with 'cascading' licensing, the order in which the license file is sequenced is important. Try putting your 'most valuable' products (e.g. Revit) at the beginning.
See an earlier post of mine for reference:
thats not it
this is a known issue
here is the workaround: http://upandready.typepad.com/up_and_ready/2013/07/education-master-suite-2014-revit-2014.html
DarrenP
