Hi guys,
I have tried to installl Revit Arch 12 for 5th times and installation failed at verious stages (during or after the activation process)-Please help to have it this solved asap. I already removed all material library in my computer and disabled Anti-Virus software as well.
Here is the latest message from Revit Arch 12. Looking forward to hear from you guys.
Tony
2011/8/23:13:50:44 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/8/23:13:50:44 Tony Tran DELL-30805731C4 Launch
2011/8/23:13:51:54 Tony Tran DELL-30805731C4 === Setup ended ===
2011/8/23:13:50:50 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/8/23:13:50:50 Tony Tran DELL-30805731C4 Launch
2011/8/23:13:52:01 Tony Tran DELL-30805731C4 PageOpen LaunchDialog
2011/8/23:13:53:21 Tony Tran DELL-30805731C4 PageOpen LicenseDialog
2011/8/23:13:55:49 Tony Tran DELL-30805731C4 PageOpen ProductInfoDialog
2011/8/23:13:56:25 Tony Tran DELL-30805731C4 PageOpen ProductSelectionDialog2
2011/8/23:13:56:43 Tony Tran DELL-30805731C4 PageOpen FullProgressDialog
2011/8/23:13:56:43 Tony Tran DELL-30805731C4 Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\vcredist_x86_2005.log"" "
2011/8/23:13:57:16 Tony Tran DELL-30805731C4 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2011/8/23:13:57:16 Tony Tran DELL-30805731C4 Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\vcredist_x86_2010.log
2011/8/23:13:57:38 Tony Tran DELL-30805731C4 Install Microsoft Visual C++ 2010 Redistributable (x86) Succeeded
2011/8/23:13:57:38 Tony Tran DELL-30805731C4 Installing .NET Framework Runtime 4.0: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2011/8/23:14:07:12 Tony Tran DELL-30805731C4 Install .NET Framework Runtime 4.0 Succeeded
2011/8/23:14:07:13 Tony Tran DELL-30805731C4 Installing Autodesk® Design Review 2012: TRANSFORMS="C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI7.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/8/23:14:09:46 Tony Tran DELL-30805731C4 Install Autodesk® Design Review 2012 Succeeded
2011/8/23:14:09:46 Tony Tran DELL-30805731C4 Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/8/23:14:11:53 Tony Tran DELL-30805731C4 Install DirectX® Runtime Succeeded
2011/8/23:14:12:03 Tony Tran DELL-30805731C4 Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\x86\en-us\RAC2012\RAC2012.mst;C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI7.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/8/23:14:46:12 Tony Tran DELL-30805731C4 Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
2011/8/23:14:46:13 Tony Tran DELL-30805731C4 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2011/8/23:14:47:30 Tony Tran DELL-30805731C4 Rollback Autodesk® Design Review 2012 Succeeded
2011/8/23:14:47:30 Tony Tran DELL-30805731C4 Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
2011/8/23:14:47:31 Tony Tran DELL-30805731C4 Rollback Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1619
2011/8/23:14:47:31 Tony Tran DELL-30805731C4 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2011/8/23:14:47:36 Tony Tran DELL-30805731C4 PageOpen InstallCompleteDialog
2011/8/23:14:58:44 Tony Tran DELL-30805731C4 === Setup ended ===
2011/8/26:16:14:12 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/8/26:16:14:12 Tony Tran DELL-30805731C4 Launch
2011/8/26:16:15:37 Tony Tran DELL-30805731C4 === Setup ended ===
2011/8/26:16:14:15 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/8/26:16:14:15 Tony Tran DELL-30805731C4 Launch
2011/8/26:16:15:39 Tony Tran DELL-30805731C4 PageOpen LaunchDialog
2011/8/26:16:16:43 Tony Tran DELL-30805731C4 PageOpen LicenseDialog
2011/8/26:16:16:58 Tony Tran DELL-30805731C4 PageOpen ProductInfoDialog
2011/8/26:16:18:20 Tony Tran DELL-30805731C4 === Setup ended ===
2011/8/28:20:09:23 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/8/28:20:09:23 Tony Tran DELL-30805731C4 Launch
2011/8/28:20:10:50 Tony Tran DELL-30805731C4 === Setup ended ===
2011/8/28:20:09:26 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/8/28:20:09:26 Tony Tran DELL-30805731C4 Launch
2011/8/28:20:10:53 Tony Tran DELL-30805731C4 PageOpen LaunchDialog
2011/8/28:20:15:50 Tony Tran DELL-30805731C4 PageOpen LicenseDialog
2011/8/28:20:16:00 Tony Tran DELL-30805731C4 PageOpen ProductInfoDialog
2011/8/28:20:34:47 Tony Tran DELL-30805731C4 PageOpen ProductSelectionDialog2
2011/8/28:20:35:09 Tony Tran DELL-30805731C4 PageOpen FullProgressDialog
2011/8/28:20:35:09 Tony Tran DELL-30805731C4 Installing Autodesk® Design Review 2012: TRANSFORMS="C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI1.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/8/28:20:36:38 Tony Tran DELL-30805731C4 Install Autodesk® Design Review 2012 Succeeded
2011/8/28:20:36:38 Tony Tran DELL-30805731C4 Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/8/28:20:38:47 Tony Tran DELL-30805731C4 Install DirectX® Runtime Succeeded
2011/8/28:20:38:51 Tony Tran DELL-30805731C4 Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\x86\en-us\RAC2012\RAC2012.mst;C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI1.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/8/28:20:39:39 Tony Tran DELL-30805731C4 Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
2011/8/28:20:39:39 Tony Tran DELL-30805731C4 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2011/8/28:20:41:37 Tony Tran DELL-30805731C4 Rollback Autodesk® Design Review 2012 Succeeded
2011/8/28:20:41:38 Tony Tran DELL-30805731C4 PageOpen InstallCompleteDialog
2011/8/28:20:54:02 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/11:10:08:51 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/11:10:08:51 Tony Tran DELL-30805731C4 Launch
2011/9/11:10:10:33 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/11:10:08:55 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/11:10:08:55 Tony Tran DELL-30805731C4 Launch
2011/9/11:10:10:36 Tony Tran DELL-30805731C4 PageOpen LaunchDialog
2011/9/11:19:26:50 Tony Tran DELL-30805731C4 PageOpen LicenseDialog
2011/9/11:19:26:56 Tony Tran DELL-30805731C4 PageOpen ProductInfoDialog
2011/9/11:20:22:32 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/11:22:30:21 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/11:22:30:21 Tony Tran DELL-30805731C4 Launch
2011/9/11:22:31:23 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/11:22:30:23 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/11:22:30:23 Tony Tran DELL-30805731C4 Launch
2011/9/11:22:31:26 Tony Tran DELL-30805731C4 PageOpen LaunchDialog
2011/9/11:22:37:21 Tony Tran DELL-30805731C4 PageOpen LicenseDialog
2011/9/11:22:40:53 Tony Tran DELL-30805731C4 PageOpen ProductInfoDialog
2011/9/11:22:41:21 Tony Tran DELL-30805731C4 PageOpen ProductSelectionDialog2
2011/9/11:22:41:42 Tony Tran DELL-30805731C4 PageOpen FullProgressDialog
2011/9/11:22:41:42 Tony Tran DELL-30805731C4 Installing Autodesk® Design Review 2012: TRANSFORMS="C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI3.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/11:22:43:34 Tony Tran DELL-30805731C4 Install Autodesk® Design Review 2012 Succeeded
2011/9/11:22:43:34 Tony Tran DELL-30805731C4 Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/9/11:22:46:13 Tony Tran DELL-30805731C4 Install DirectX® Runtime Succeeded
2011/9/11:22:46:15 Tony Tran DELL-30805731C4 Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\x86\en-us\RAC2012\RAC2012.mst;C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI3.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/11:22:47:18 Tony Tran DELL-30805731C4 Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
2011/9/11:22:47:18 Tony Tran DELL-30805731C4 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2011/9/11:22:48:17 Tony Tran DELL-30805731C4 Rollback Autodesk® Design Review 2012 Succeeded
2011/9/11:22:48:17 Tony Tran DELL-30805731C4 PageOpen InstallCompleteDialog
2011/9/11:23:16:16 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/14:16:02:33 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/14:16:02:33 Tony Tran DELL-30805731C4 Launch
2011/9/14:16:04:04 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/14:16:02:36 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/14:16:02:36 Tony Tran DELL-30805731C4 Launch
2011/9/14:16:04:09 Tony Tran DELL-30805731C4 PageOpen LaunchDialog
2011/9/14:16:06:21 Tony Tran DELL-30805731C4 PageOpen LicenseDialog
2011/9/14:16:06:29 Tony Tran DELL-30805731C4 PageOpen ProductInfoDialog
2011/9/14:16:07:23 Tony Tran DELL-30805731C4 PageOpen ProductSelectionDialog2
2011/9/14:16:07:33 Tony Tran DELL-30805731C4 PageOpen FullProgressDialog
2011/9/14:16:07:33 Tony Tran DELL-30805731C4 Installing Autodesk® Design Review 2012: TRANSFORMS="C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI35.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/14:16:10:41 Tony Tran DELL-30805731C4 Install Autodesk® Design Review 2012 Succeeded
2011/9/14:16:10:41 Tony Tran DELL-30805731C4 Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/9/14:16:14:06 Tony Tran DELL-30805731C4 Install DirectX® Runtime Succeeded
2011/9/14:16:14:29 Tony Tran DELL-30805731C4 Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\x86\en-us\RAC2012\RAC2012.mst;C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI35.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/14:16:15:37 Tony Tran DELL-30805731C4 Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
2011/9/14:16:15:39 Tony Tran DELL-30805731C4 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2011/9/14:16:18:16 Tony Tran DELL-30805731C4 Rollback Autodesk® Design Review 2012 Succeeded
2011/9/14:16:18:19 Tony Tran DELL-30805731C4 PageOpen InstallCompleteDialog
2011/9/14:16:18:59 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/14:17:16:26 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/14:17:16:26 Tony Tran DELL-30805731C4 Launch
2011/9/14:17:17:21 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/14:17:16:28 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/14:17:16:28 Tony Tran DELL-30805731C4 Launch
2011/9/14:17:17:22 Tony Tran DELL-30805731C4 PageOpen LaunchDialog
2011/9/14:17:18:17 Tony Tran DELL-30805731C4 PageOpen LicenseDialog
2011/9/14:17:18:22 Tony Tran DELL-30805731C4 PageOpen ProductInfoDialog
2011/9/14:17:18:47 Tony Tran DELL-30805731C4 PageOpen ProductSelectionDialog2
2011/9/14:17:18:53 Tony Tran DELL-30805731C4 PageOpen FullProgressDialog
2011/9/14:17:18:53 Tony Tran DELL-30805731C4 Installing Autodesk® Design Review 2012: TRANSFORMS="C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI167.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/14:17:20:18 Tony Tran DELL-30805731C4 Install Autodesk® Design Review 2012 Succeeded
2011/9/14:17:20:18 Tony Tran DELL-30805731C4 Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/9/14:17:21:28 Tony Tran DELL-30805731C4 Install DirectX® Runtime Succeeded
2011/9/14:17:21:31 Tony Tran DELL-30805731C4 Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\x86\en-us\RAC2012\RAC2012.mst;C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI167.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/14:17:22:03 Tony Tran DELL-30805731C4 Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
2011/9/14:17:22:04 Tony Tran DELL-30805731C4 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2011/9/14:17:23:30 Tony Tran DELL-30805731C4 Rollback Autodesk® Design Review 2012 Succeeded
2011/9/14:17:23:31 Tony Tran DELL-30805731C4 PageOpen InstallCompleteDialog
2011/9/14:17:24:07 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/14:19:48:15 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/14:19:48:15 Tony Tran DELL-30805731C4 Launch
2011/9/14:19:49:11 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/14:19:48:18 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/14:19:48:18 Tony Tran DELL-30805731C4 Launch
2011/9/14:19:49:12 Tony Tran DELL-30805731C4 PageOpen LaunchDialog
2011/9/14:19:51:44 Tony Tran DELL-30805731C4 PageOpen LicenseDialog
2011/9/14:19:51:52 Tony Tran DELL-30805731C4 PageOpen ProductInfoDialog
2011/9/14:19:52:45 Tony Tran DELL-30805731C4 PageOpen ProductSelectionDialog2
2011/9/14:19:52:51 Tony Tran DELL-30805731C4 PageOpen FullProgressDialog
2011/9/14:19:52:51 Tony Tran DELL-30805731C4 Installing Autodesk® Design Review 2012: TRANSFORMS="C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI9F.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/14:19:54:08 Tony Tran DELL-30805731C4 Install Autodesk® Design Review 2012 Succeeded
2011/9/14:19:54:08 Tony Tran DELL-30805731C4 Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/9/14:19:55:27 Tony Tran DELL-30805731C4 Install DirectX® Runtime Succeeded
2011/9/14:19:55:28 Tony Tran DELL-30805731C4 Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\x86\en-us\RAC2012\RAC2012.mst;C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI9F.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/14:19:56:07 Tony Tran DELL-30805731C4 Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
2011/9/14:19:56:07 Tony Tran DELL-30805731C4 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2011/9/14:19:56:53 Tony Tran DELL-30805731C4 Rollback Autodesk® Design Review 2012 Succeeded
2011/9/14:19:56:54 Tony Tran DELL-30805731C4 PageOpen InstallCompleteDialog
2011/9/14:19:58:19 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/14:20:31:46 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/14:20:31:46 Tony Tran DELL-30805731C4 Launch
2011/9/14:20:32:37 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/14:20:31:48 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/14:20:31:48 Tony Tran DELL-30805731C4 Launch
2011/9/14:20:32:38 Tony Tran DELL-30805731C4 PageOpen LaunchDialog
2011/9/14:20:41:32 Tony Tran DELL-30805731C4 PageOpen LicenseDialog
2011/9/14:20:41:48 Tony Tran DELL-30805731C4 PageOpen ProductInfoDialog
2011/9/14:20:42:11 Tony Tran DELL-30805731C4 PageOpen ProductSelectionDialog2
2011/9/14:20:42:15 Tony Tran DELL-30805731C4 PageOpen FullProgressDialog
2011/9/14:20:42:16 Tony Tran DELL-30805731C4 Installing Autodesk® Design Review 2012: TRANSFORMS="C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI1AF.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/14:20:43:21 Tony Tran DELL-30805731C4 Install Autodesk® Design Review 2012 Succeeded
2011/9/14:20:43:21 Tony Tran DELL-30805731C4 Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/9/14:20:44:30 Tony Tran DELL-30805731C4 Install DirectX® Runtime Succeeded
2011/9/14:20:44:31 Tony Tran DELL-30805731C4 Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\x86\en-us\RAC2012\RAC2012.mst;C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI1AF.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/14:20:45:08 Tony Tran DELL-30805731C4 Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
2011/9/14:20:45:08 Tony Tran DELL-30805731C4 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2011/9/14:20:45:46 Tony Tran DELL-30805731C4 Rollback Autodesk® Design Review 2012 Succeeded
2011/9/14:20:45:47 Tony Tran DELL-30805731C4 PageOpen InstallCompleteDialog
2011/9/14:20:49:37 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/14:21:28:08 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/14:21:28:08 Tony Tran DELL-30805731C4 Launch
2011/9/14:21:28:56 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/14:21:28:10 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/14:21:28:10 Tony Tran DELL-30805731C4 Launch
2011/9/14:21:28:58 Tony Tran DELL-30805731C4 PageOpen LaunchDialog
2011/9/14:21:30:19 Tony Tran DELL-30805731C4 PageOpen LicenseDialog
2011/9/14:21:30:24 Tony Tran DELL-30805731C4 PageOpen ProductInfoDialog
2011/9/14:21:30:56 Tony Tran DELL-30805731C4 PageOpen ProductSelectionDialog2
2011/9/14:21:31:09 Tony Tran DELL-30805731C4 PageOpen FullProgressDialog
2011/9/14:21:31:10 Tony Tran DELL-30805731C4 Installing Autodesk® Design Review 2012: TRANSFORMS="C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI2.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/14:21:32:12 Tony Tran DELL-30805731C4 Install Autodesk® Design Review 2012 Succeeded
2011/9/14:21:32:12 Tony Tran DELL-30805731C4 Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/9/14:21:33:33 Tony Tran DELL-30805731C4 Install DirectX® Runtime Succeeded
2011/9/14:21:33:34 Tony Tran DELL-30805731C4 Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\x86\en-us\RAC2012\RAC2012.mst;C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI2.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/14:21:34:06 Tony Tran DELL-30805731C4 Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
2011/9/14:21:34:06 Tony Tran DELL-30805731C4 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2011/9/14:21:34:54 Tony Tran DELL-30805731C4 Rollback Autodesk® Design Review 2012 Succeeded
2011/9/14:21:34:55 Tony Tran DELL-30805731C4 PageOpen InstallCompleteDialog
2011/9/14:21:41:16 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/15:15:43:17 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/15:15:43:17 Tony Tran DELL-30805731C4 Launch
2011/9/15:15:44:20 Tony Tran DELL-30805731C4 === Setup ended ===
2011/9/15:15:43:21 Tony Tran DELL-30805731C4 === Setup started on DELL-30805731C4 by Tony Tran ===
2011/9/15:15:43:21 Tony Tran DELL-30805731C4 Launch
2011/9/15:15:44:22 Tony Tran DELL-30805731C4 PageOpen LaunchDialog
2011/9/15:15:46:17 Tony Tran DELL-30805731C4 PageOpen LicenseDialog
2011/9/15:15:48:31 Tony Tran DELL-30805731C4 PageOpen ProductInfoDialog
2011/9/15:15:51:01 Tony Tran DELL-30805731C4 PageOpen ProductSelectionDialog2
2011/9/15:15:51:10 Tony Tran DELL-30805731C4 PageOpen FullProgressDialog
2011/9/15:15:51:22 Tony Tran DELL-30805731C4 Installing Autodesk® Design Review 2012: TRANSFORMS="C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI53.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/15:15:54:07 Tony Tran DELL-30805731C4 Install Autodesk® Design Review 2012 Succeeded
2011/9/15:15:54:07 Tony Tran DELL-30805731C4 Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/9/15:15:57:49 Tony Tran DELL-30805731C4 Install DirectX® Runtime Succeeded
2011/9/15:15:57:59 Tony Tran DELL-30805731C4 Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\x86\en-us\RAC2012\RAC2012.mst;C:\DOCUME~1\TONYTR~1\LOCALS~1\Temp\_AI53.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/15:16:01:38 Tony Tran DELL-30805731C4 Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
2011/9/15:16:01:38 Tony Tran DELL-30805731C4 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2011/9/15:16:02:23 Tony Tran DELL-30805731C4 Rollback Autodesk® Design Review 2012 Succeeded
