Im not sure what the problem is but after initial install the ribbon seems to not work properly
when i select and item to edit. that will be the only dialog option i will receive even when editing something different.
example:
If i select to edit Text first, then try to edit a wall i will only see the options to edit text even though i have a wall selected.
I have now idea what to ask to resolve this problem. what am i doing wrong? thanks for the the help
EDIT: after about 5min after i posted this i found the answer I think i needed to install the Update Release 2 so the Contextual Panels will display or update correctly
http://revitclinic.typepad.com/my_weblog/2012/05/revit-2013-2012-contextual-panels-do-not-display-or...
