Installation & Licensing
RE-Installation Problems and plotting issues
3 REPLIES 3
1979afsana
213 Views, 3 Replies
i had student autocad installed on my computer.  My computer crashed and I had to reinstall autocad on it.  First it wouldn't let me reinstall it using install and download command and then i installed it using wed download.  And after the installation it doesn't open.  Can you guys please help me out ASAP.  I have projects due and I can't work on em cause of this issue.  I was also having plot issues before so i also need help in that.
3 REPLIES 3
philip.s
in reply to: 1979afsana
Welcome to the community Afsana!
Did the install complete without any errors? Can you please check your install log to verify?
1979afsana
in reply to: philip.s
Thanks for replying back.  How do I check the install log?
Sent from Samsung Mobile
philip.s
You're welcome Afsana!
The install log access instructions are detailed in the previously provided link. Specifically:
1) Click Start menu (Windows) > Run.
2) In the Run dialog box, enter %TEMP% and click OK.
3) Click View menu > Details, and then click the Date Modified column header twice so that the most recent files are listed at the top.
4) The log file is generally called <Product Name>.log.
Administrator Productivity
