Installation & Licensing
RCVD: A License error has occurred.
4 REPLIES 4
huberb1024
2409 Views, 4 Replies
Contact your technical support representative for assistance.  To help determine the nature of the problem, the error code is:  -157.424.0
serial number:  xxx-xxxxxxxx
product code:  001d1
This user was moved from a Winxp system to a Win7 system and required re-installation.
Please be aware that this is a public forum posting serial numbers or personal information is not advised
Edited by
Discussion_Admin
4 REPLIES 4
TravisNave
in reply to: huberb1024
Did you install Windows 7 fresh and install the Autodesk product fresh?  The -157 is a damaged license error and requires complete repair. Probably need to blow away all the licensing files, if they exist, and then reactivate.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
huberb1024
Understood.  Sorry about the serial number and product code - will be more careful next time.
I installed/reimaged system, installed Autocad from scratch.  I did do the easy transfer though.  Don’t know if that kinda screwed it up.  Where are the license files I may have to kill?
TravisNave
%programdata%\flexnet
Delete the adsk*.data files.
Autodesk Forums:
huberb1024
Thanks.
Administrator Productivity
