Installation & Licensing
Question on deploying acad 2008
5 REPLIES 5
282 Views, 5 Replies
In previous releases the deployment wizard would create an MSI file with all customizations included in it. Then I could just roll out the MSI through active directory.
However, thi time around i get a shortcut instead which points to an INI file. The problem is, I can only use an MSI to deploy through Active Directory.
How has everyone else been deploying acad 2008?
5 REPLIES 5
UPDATE:
I found the .MSI and .MST files in the admin folder for my deployment package. I pushed them both out through active directory....
acad opens fine, but it did not load any of the custom configurations (ie: search paths)
UPDATE:
I can now get all the search paths, acad opens fine, but i get several error messages in the process. Anyone seen these messages?
See Attachment.
It sounds like you need to go to Control Panel -> Add/Remove Programs ->
AcadR2008 -> Change -> Repair.
John
wrote in message news:5703606@discussion.autodesk.com...
UPDATE:
See Attachment.
thanks. but this is an original install through group policy.
i need to roll it out to 500 users. i cant really have that happening.
jules.marcil
Hi ;
I have a deployment of Autodesk Products 2008 scheduled for Jan 2008 and I'm getting the same errors as you. Did you find a fix for it. Any Help would be greatly appreciated.
Jules
Administrator Productivity
