In previous releases the deployment wizard would create an MSI file with all customizations included in it. Then I could just roll out the MSI through active directory.
However, thi time around i get a shortcut instead which points to an INI file. The problem is, I can only use an MSI to deploy through Active Directory.
How has everyone else been deploying acad 2008?
