When I try to run the downloaded, with the firewall & AV both off, it still give me and error saying that the communications with the Autodesk server was lost and list of possible problems.
I've tried a few time with out success. Can some one give me a link to the files
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Good Luck!
you can download from here
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links>Autodesk Suites>Product Design Suites>Product Design Suite Ultimate
Please accept as a solution if this fully resolves the issue
DarrenP
