When trying to install this suite I first see a list of available programs :
Inventor ...
Autocad ...
All of them except Inventor (red sign) are marked OK for install.
How can I get it checkmarked?
Should I uninstall Inventor 2011 first? I have got all 2011 programs on my PC.
Jacek
Solved by RogerMollon. Go to Solution.
Jacek,
Hold the cursor over the red signal and tooltip will tell you why Inventor isn't ready to install, there is most likely a prerequisite that has to be installed first.
I hope this helps,
what did the tooltip say?
DarrenP
There were two components listed in the tooltip:
Autodesk Material Library 2012 (product version: 2.5.0.4. product language: 1033)
Autodesk Material Library Base Resolution Image Library (product version: 2.5.0.4. product language: 1033)
Did you uninstall 2011 before installing 2012
