• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    jazapata33
    Accepted Solution
    Product Design Suite 2013 licensing issues
    468 Views, 8 Replies
    11-12-2012 06:51 AM
    We just bought a new laptop for engineering and I have recently installed Autodesk product design suite 2013 on it. We have network licenses. When I connect it to the network directly through a LAN connection and try to open the software I receive an error. See attached image file.
    I have taken the laptop else where and I have VPN into the server and it worked. Is there any reason this may be working with VPN but not with direct connection.
    I also have checked to make sure there were enough license available for use.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Product Design Suite 2013 licensing issues
    11-12-2012 08:55 AM in reply to: jazapata33
    Yes.  It is likely IPv6 or a combination of that and Firewall blocking ports 2080 and 27000.
    For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    jazapata33
    11-12-2012 11:13 AM in reply to: TravisNave
    why would that be an issue if my workstation works fine with the same connection? Just curious.
    *Expert Elite*
    TravisNave
    11-12-2012 11:22 AM in reply to: jazapata33
    Because of the IP protocol in use, would be my guess.
    You might PING the server from your LAN connection with the problem and make sure that the response is a valid IPv4 address.  You can also check with Internet Explorer on the firewall ports:
    http://servername:2080
    http://servername:27000
    Those two should give a jargon response page if open.  (replace servername with your NLM server hostname.)
    Travis Nave
    Active Member
    jazapata33
    11-14-2012 09:16 AM in reply to: TravisNave
    Alright I have the laptop connected through the LAN and have pinged the server. Here is the image of the server ping look just like my workstation ping.
    *Expert Elite*
    TravisNave
    11-14-2012 09:19 AM in reply to: jazapata33
    You need to PING by hostname, not IP address.  Repost your results.
    Travis Nave
    Active Member
    jazapata33
    11-14-2012 10:33 AM in reply to: TravisNave
    alright Here is what it looks like after I ping to by the server name. Also I am fairly new to all of this installation information so bare with me please.
    *Expert Elite*
    TravisNave
    11-14-2012 10:42 AM in reply to: jazapata33
    No problem.  It is exactly as I had predicted.  The reason you can't get licenses is because the connection trying to be made to the NLM server is IPv6.  This can be fixed by modifying the hosts file on the client machine to point to the IPv4 address (the one you PING'ed first) instead.
    The entire process is in my IPv6 fix.  Instead of the 127.0.0.1 (localhost) listed in my link, use the IP address of the NLM server along with its hostname on a separate line.  That should fix you up.
    Essentially your hosts file entry should look like this:
    10.100.0.48     RYKO5
    Then when you PING it as you did in your last screen capture, it will be correct instead of the IPv6 jargon you saw instead.
    Travis Nave
    Active Member
    jazapata33
    11-14-2012 10:58 AM in reply to: TravisNave
    Thanks for all your help. your solutions has fixed the issue.
