• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    steve.sadler
    Problems with installing AutoCad Architecture 2012
    222 Views, 1 Replies
    07-27-2011 01:15 PM
    I have tried installing this on 4 occasions, with little success, on the install I tick the UK component and express tools box, and then it installs no problem. ...but on opening the programme it cant find the ACA_uk.cui file (it isn't in the folder it should be). also not installed are a number of folders which included the detail component database. The main dictonary is also missing.
    Please see attached which gives a little more information...
    I am running it on a company laptop (Windows XP), but do have quite strict permissions on my internet access etc...
    Any help would be greatly appreciated:smileysad:
    regards
    Steve
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Problems with installing AutoCad Architecture 2012
    07-28-2011 08:47 AM in reply to: steve.sadler
    You have to install with local administrator rights.  If your policy is too restrictive, you're going to have issues.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
