I've got some problem with installation Autodesk Subbassembly Composer:
"Error
Autodesk Subassembly Composer Support Pack on AutoCAD Civil 3D 2011 - Polish is incompatible with Autodesk Vault Explorer 2011 AutoCAD Civil 3D add-in. To install, the AutoCAD Civil 3D 2011 Vault 2011 Add-In must be uninstalled."
Unfortunatelly after uninstallation Vault 2011 the problem is still the same.
Thank you in advance!
Please uninstall Civil 3D 2011, reboot and reinstall the software:
http://usa.autodesk.com/getdoc/id=TS14929539
"Anyone using Vault cannot install the SAC or the support files – it’s an incompatibility issue with .NET. I would check to see exactly what they uninstalled." Thanks to the http://beingcivil.typepad.com/ team.
