• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Problems with Maya 2013 reinstallation
    920 Views, 4 Replies
    11-16-2012 08:14 AM
    I recently unistalled my Maya 2013 Student Edition. I even did it the way Autodesk wants you too from these steps: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
    HOWEVER, now I want to reinstall it and it keeps telling me that Maya itself is still installed and I can only install the stuff that comes with it. Now when I search my computer it tells me that Maya cannot be found and says I need to locate this file: C:\Autodesk\WI\Autodesk Maya 2013\x64\Maya\Maya2013.cab
    Is there any way I can get help on this matter so I can have Maya 2013 up and running again. Or is it possible to send me just that file to install into my system so it can read it?
    Thanks.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Problems with Maya 2013 reinstallation
    11-19-2012 10:01 AM in reply to: svelez
    To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
    http://support.microsoft.com/mats/Program_Install_and_Uninstall
    For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
    For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Product Support
    11-19-2012 01:21 PM in reply to: svelez
    svelez,
    Hello. You may be having problems with one particular key. Can you delete this key and try to install:
    HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\EC4807CF09050774B8B5AC135225F6D0
    Thank you for taking part in our community!
    David Dembkoski
    Product Support Specialist
    Autodesk Product Support
    New Member
    11-20-2012 12:07 PM in reply to: dembkod
    Ok. Thanks.
     Well I was able to get it installed but now I get an error saying;
    "maya.exe" This application was unable to start correctly (0xc000007b). Click OK to close the application.
    So I am still unable to use it. How can I fix this.
    Product Support
    11-20-2012 12:15 PM in reply to: svelez
    svelez,
    Hello. This could be a corrupt Direct X component.,
    http://forums.autodesk.com/t5/Installation-Licensing/Problems-with-Maya-2013-reinstallation/m-p/3706...
    http://community.softimage.com/forum/autodesk-3ds-max/autodesk-3ds-max--3ds-max-design-2011/max-2011...
    Next, you could uninstall the program and reinstall. I know you already uninstalled manually, but sometimes a clean uninstall process through the Control Panel works wonders.
    David Dembkoski
