Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Problems with Maya 2013 reinstalla tion
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I recently unistalled my Maya 2013 Student Edition. I even did it the way Autodesk wants you too from these steps: http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
HOWEVER, now I want to reinstall it and it keeps telling me that Maya itself is still installed and I can only install the stuff that comes with it. Now when I search my computer it tells me that Maya cannot be found and says I need to locate this file: C:\Autodesk\WI\Autodesk Maya 2013\x64\Maya\Maya2013.cab
Is there any way I can get help on this matter so I can have Maya 2013 up and running again. Or is it possible to send me just that file to install into my system so it can read it?
Thanks.
Re: Problems with Maya 2013 reinstalla tion
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensi
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Problems with Maya 2013 reinstalla tion
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
svelez,
Hello. You may be having problems with one particular key. Can you delete this key and try to install:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Prod
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok. Thanks.
Well I was able to get it installed but now I get an error saying;
"maya.exe" This application was unable to start correctly (0xc000007b). Click OK to close the application.
So I am still unable to use it. How can I fix this.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
svelez,
Hello. This could be a corrupt Direct X component.,
Next, you could uninstall the program and reinstall. I know you already uninstalled manually, but sometimes a clean uninstall process through the Control Panel works wonders.
David Dembkoski
