Installation & Licensing
New Member
svelez
Message 1 of 6 (11,526 Views)
Problems with Maya 2013 reinstallation
11526 Views, 5 Replies
11-16-2012 08:14 AM
I recently unistalled my Maya 2013 Student Edition. I even did it the way Autodesk wants you too from these steps: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
HOWEVER, now I want to reinstall it and it keeps telling me that Maya itself is still installed and I can only install the stuff that comes with it. Now when I search my computer it tells me that Maya cannot be found and says I need to locate this file: C:\Autodesk\WI\Autodesk Maya 2013\x64\Maya\Maya2013.cab
Is there any way I can get help on this matter so I can have Maya 2013 up and running again. Or is it possible to send me just that file to install into my system so it can read it?
Thanks.
TravisNave
Message 2 of 6 (11,486 Views)
Re: Problems with Maya 2013 reinstallation
11-19-2012 10:01 AM in reply to: svelez
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Product Support
dembkod
Message 3 of 6 (11,477 Views)
11-19-2012 01:21 PM in reply to: svelez
svelez,
Hello. You may be having problems with one particular key. Can you delete this key and try to install:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\EC4807CF09050774B8B5AC135225F6D0
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
New Member
svelez
Message 4 of 6 (11,460 Views)
11-20-2012 12:07 PM in reply to: dembkod
Ok. Thanks.
 Well I was able to get it installed but now I get an error saying;
"maya.exe" This application was unable to start correctly (0xc000007b). Click OK to close the application.
So I am still unable to use it. How can I fix this.
Product Support
dembkod
Message 5 of 6 (11,455 Views)
11-20-2012 12:15 PM in reply to: svelez
svelez,
Hello. This could be a corrupt Direct X component.,
http://forums.autodesk.com/t5/Installation-Licensing/Problems-with-Maya-2013-reinstallation/m-p/3706...
http://community.softimage.com/forum/autodesk-3ds-max/autodesk-3ds-max--3ds-max-design-2011/max-2011...
Next, you could uninstall the program and reinstall. I know you already uninstalled manually, but sometimes a clean uninstall process through the Control Panel works wonders.
David Dembkoski
David Dembkoski
New Member
KumarShanu1997
Message 6 of 6 (9,968 Views)
11-20-2013 07:24 AM in reply to: dembkod
shows crc extraction failed maya2013.cab
and during actual installation reports cannot find maya 2013.cab download a fresh copy and retry
i have downloaded all the copies all fresh from maya 2011 to 2013 but similar message like "cannot find maya20xx.cab"
