I stoped the server, configurated it for another licence-file, started and
stopped it, pointed it back to the original licence-file and started it
again, and it started with FlexLM 8.2 without any errors. I've got a mail
from another person too that writes that the problem with lmgrd running wild
may be caused by virus shields. He had the same problem, and disabled
virusprotection on c:\flex and the problem was gone. So I will do that too
so maybe the problem wont come back in the future. Thanks for your help
"jerry milana" skrev i meddelandet
news:B036882D838906804E4F05CA7F8BF64A@in.WebX.maYIadrTaRb...
> Stefan,
> The current version of ADSKFLEX works just fine with LMGRD 8.2. The
change
> in behavior you have observed is the result of improvement in LMGRD's
error
> handling. You still have the same underlying problem which is likely
either
> another program using TCP Port 2080 or that port is completely blocked.
> Common types of software known to cause this are Internet security, proxy,
> firewall and virus shields. Keep in mind that Autodesk has registered
port
> 2080 with IANA so you should ask the publisher of any offending software
how
> to free this port up for ADSKFLEX.
> Jerry Milana,
> Autodesk Professional Services
> "Stefan Hellman" wrote in message
> news:FBF631CABA5B0BC6BF71236C1243739A@in.WebX.maYIadrTaRb...
> > I'm running the shipped version of FlexLM and everything worked fine.
But
> > suddenly it runned wild, and started multiple adskflex taking 100% of
the
> > processor and the server vent down. I restarted the server but the
problem
> > is still there. Then I downloaded the latest versions of the
FlexLM-files
> > from globetrotter (8.2a) and the problem was gone. But now I get this
> > problem insted:
> > 11:17:44 (lmgrd) Starting vendor daemon at port 2080
> > 11:17:44 (lmgrd) Using vendor daemon port 2080 specified in license file
> > 11:17:44 (lmgrd) REStarted adskflex (pid 2040)
> > 11:17:44 (adskflex) Server started on pelle for: 40900INVBUN_5_0F
> > 11:17:44 (adskflex) 40100ARCHDESK_3_3F
> > 11:17:45 (adskflex) Vendor daemon can't talk to lmgrd ()
> > 11:17:55 (lmgrd) Vendor daemon died with status 28
> > Why this? Do have have to have a newer version of adskflex too, or what?
