Installation & Licensing
235 Views, 3 Replies
Problems with Download
First of all I would like to say sorry if I am creating a topic in the wrong forum, but I have a problem with downloading the Autocad 2015.
I have the student license and don't know if it matters. When I try to download the "brazilian-portuguese" version, a message appears showing that the File is not found. OK, after this I try to download the "English" version, and the following msg appears to me:
(after this msg appears, I can't try to download again until restar the computer. I tried on 3 different computers and the same happens.)
Please, someone could help me ?
Thank you very much.
Tags (2)
3 REPLIES 3
M_Hensley
It looks like you are trying to install over the internet. Instead completely download the file to a hard drive then start the installation.
in reply to: M_Hensley
Thank you Mr. Hensley,
could you kindly post the link of the download to me ? I didn't find another one !
TravisNave
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Autodesk Forums:
Administrator Productivity
