Here is the log from trying to create a deployment..
2010/9/28:16:51:38 danielj KE41 === Setup started on KE41 by danielj ===
2010/9/28:16:54:21 danielj KE41 === Setup started on KE41 by danielj ===
2010/9/28:17:04:38 danielj KE41 The system cannot open the device or file specified.
2010/9/28:17:16:01 danielj KE41 === Setup ended ===
2010/9/29:08:45:45 danielj KE41 === Setup started on KE41 by danielj ===
2010/9/29:08:48:27 danielj KE41 === Setup started on KE41 by danielj ===
2010/9/29:08:49:42 danielj KE41 === Setup ended ===
2010/9/29:09:08:22 danielj KE41 Deployment VCREDIST2005X86 CreateAdminImage succeeded!
2010/9/29:09:08:22 danielj KE41 Deployment VCREDIST2005X86 Finalize succeeded!
2010/9/29:09:08:36 danielj KE41 Deployment VCREDISTX86 CreateAdminImage succeeded!
2010/9/29:09:08:36 danielj KE41 Deployment VCREDISTX86 Finalize succeeded!
2010/9/29:09:10:10 danielj KE41 Deployment DOTNET CreateAdminImage succeeded!
2010/9/29:09:10:10 danielj KE41 Deployment DOTNET Finalize succeeded!
2010/9/29:09:10:21 danielj KE41 Deployment ADR_en-us CreateTransform succeeded!
2010/9/29:09:10:49 danielj KE41 Deployment ADR_en-us CreateAdminImage succeeded!
2010/9/29:09:10:49 danielj KE41 Deployment ADR_en-us CopyUserFiles succeeded!
2010/9/29:09:10:49 danielj KE41 Deployment ADR_en-us Finalize succeeded!
2010/9/29:09:12:36 danielj KE41 Deployment VBA CreateAdminImage succeeded!
2010/9/29:09:12:36 danielj KE41 Deployment VBA Finalize succeeded!
2010/9/29:09:13:01 danielj KE41 Deployment DIRECTX CreateAdminImage succeeded!
2010/9/29:09:13:01 danielj KE41 Deployment DIRECTX Finalize succeeded!
2010/9/29:09:13:05 danielj KE41 Deployment MSXML CreateAdminImage succeeded!
2010/9/29:09:13:05 danielj KE41 Deployment MSXML Finalize succeeded!
2010/9/29:09:16:16 danielj KE41 Deployment DWGTRUEVIEW CreateAdminImage failed!
2010/9/29:10:02:43 danielj KE41 Deployment VCREDIST2005X86 CreateAdminImage succeeded!
2010/9/29:10:02:43 danielj KE41 Deployment VCREDIST2005X86 Finalize succeeded!
2010/9/29:10:02:55 danielj KE41 Deployment VCREDISTX86 CreateAdminImage succeeded!
2010/9/29:10:02:55 danielj KE41 Deployment VCREDISTX86 Finalize succeeded!
2010/9/29:10:04:26 danielj KE41 Deployment DOTNET CreateAdminImage succeeded!
2010/9/29:10:04:26 danielj KE41 Deployment DOTNET Finalize succeeded!
2010/9/29:10:04:29 danielj KE41 Deployment ADR_en-us CreateTransform succeeded!
2010/9/29:10:05:08 danielj KE41 Deployment ADR_en-us CreateAdminImage succeeded!
2010/9/29:10:05:08 danielj KE41 Deployment ADR_en-us CopyUserFiles succeeded!
2010/9/29:10:05:08 danielj KE41 Deployment ADR_en-us Finalize succeeded!
2010/9/29:10:07:07 danielj KE41 Deployment VBA CreateAdminImage succeeded!
2010/9/29:10:07:07 danielj KE41 Deployment VBA Finalize succeeded!
2010/9/29:10:07:36 danielj KE41 Deployment DIRECTX CreateAdminImage succeeded!
2010/9/29:10:07:36 danielj KE41 Deployment DIRECTX Finalize succeeded!
2010/9/29:10:07:41 danielj KE41 Deployment MSXML CreateAdminImage succeeded!
2010/9/29:10:07:41 danielj KE41 Deployment MSXML Finalize succeeded!
2010/9/29:10:12:53 danielj KE41 Deployment DWGTRUEVIEW CreateAdminImage succeeded!
2010/9/29:10:12:53 danielj KE41 Deployment DWGTRUEVIEW Finalize succeeded!
2010/9/29:10:12:58 danielj KE41 Deployment WMF90 CreateAdminImage succeeded!
2010/9/29:10:12:58 danielj KE41 Deployment WMF90 Finalize succeeded!
2010/9/29:10:13:00 danielj KE41 Deployment WSE30 CreateAdminImage succeeded!
2010/9/29:10:13:00 danielj KE41 Deployment WSE30 Finalize succeeded!
2010/9/29:10:14:01 danielj KE41 Deployment INVENTOR CreateTransform succeeded!
2010/9/29:10:59:40 danielj KE41 Deployment INVENTOR CreateAdminImage succeeded!
2010/9/29:11:00:09 danielj KE41 Deployment INVENTOR ApplyPatch succeeded!
2010/9/29:11:00:09 danielj KE41 Deployment INVENTOR CopyUserFiles succeeded!
2010/9/29:11:00:09 danielj KE41 Deployment INVENTOR Finalize succeeded!
2010/9/29:11:08:05 danielj KE41 Deployment INVENTOR_en-us CreateAdminImage succeeded!
2010/9/29:11:08:05 danielj KE41 Deployment INVENTOR_en-us Finalize succeeded!
2010/9/29:11:09:40 danielj KE41 Deployment ACM CreateTransform succeeded!
2010/9/29:11:56:24 danielj KE41 Deployment ACM CreateAdminImage succeeded!
2010/9/29:11:56:28 danielj KE41 Deployment ACM ApplyPatch succeeded!
2010/9/29:11:56:28 danielj KE41 Deployment ACM CopyUserFiles succeeded!
2010/9/29:11:56:33 danielj KE41 Deployment ACM CreateGPOMsi failed!
2010/9/29:12:04:03 danielj KE41 === Setup started on KE41 by danielj ===
2010/9/29:12:04:03 danielj KE41 An instance of setup is already running. Only one instance of setup can run at a time.2010/9/29:12:04:12 danielj KE41 === Setup ended ===
2010/9/29:12:37:35 danielj KE41 Deployment VCREDIST2005X86 CreateAdminImage succeeded!
2010/9/29:12:37:35 danielj KE41 Deployment VCREDIST2005X86 Finalize succeeded!
2010/9/29:12:37:49 danielj KE41 Deployment VCREDISTX86 CreateAdminImage succeeded!
2010/9/29:12:37:49 danielj KE41 Deployment VCREDISTX86 Finalize succeeded!
2010/9/29:12:39:22 danielj KE41 Deployment DOTNET CreateAdminImage succeeded!
2010/9/29:12:39:22 danielj KE41 Deployment DOTNET Finalize succeeded!
2010/9/29:12:39:34 danielj KE41 Deployment ADR_en-us CreateTransform succeeded!
2010/9/29:12:40:01 danielj KE41 Deployment ADR_en-us CreateAdminImage succeeded!
2010/9/29:12:40:01 danielj KE41 Deployment ADR_en-us CopyUserFiles succeeded!
2010/9/29:12:40:01 danielj KE41 Deployment ADR_en-us Finalize succeeded!
2010/9/29:12:41:49 danielj KE41 Deployment VBA CreateAdminImage succeeded!
2010/9/29:12:41:49 danielj KE41 Deployment VBA Finalize succeeded!
2010/9/29:12:42:14 danielj KE41 Deployment DIRECTX CreateAdminImage succeeded!
2010/9/29:12:42:14 danielj KE41 Deployment DIRECTX Finalize succeeded!
2010/9/29:12:42:19 danielj KE41 Deployment MSXML CreateAdminImage succeeded!
2010/9/29:12:42:19 danielj KE41 Deployment MSXML Finalize succeeded!
2010/9/29:12:46:59 danielj KE41 Deployment DWGTRUEVIEW CreateAdminImage succeeded!
2010/9/29:12:46:59 danielj KE41 Deployment DWGTRUEVIEW Finalize succeeded!
2010/9/29:12:47:04 danielj KE41 Deployment WMF90 CreateAdminImage succeeded!
2010/9/29:12:47:04 danielj KE41 Deployment WMF90 Finalize succeeded!
2010/9/29:12:47:06 danielj KE41 Deployment WSE30 CreateAdminImage succeeded!
2010/9/29:12:47:06 danielj KE41 Deployment WSE30 Finalize succeeded!
2010/9/29:12:48:25 danielj KE41 Deployment INVENTOR CreateTransform succeeded!
2010/9/29:13:35:18 danielj KE41 Deployment INVENTOR CreateAdminImage succeeded!
2010/9/29:13:35:43 danielj KE41 Deployment INVENTOR ApplyPatch succeeded!
2010/9/29:13:35:43 danielj KE41 Deployment INVENTOR CopyUserFiles succeeded!
2010/9/29:13:35:43 danielj KE41 Deployment INVENTOR Finalize succeeded!
2010/9/29:13:35:43 danielj KE41 The system cannot open the device or file specified.
2010/9/29:13:43:51 danielj KE41 Deployment INVENTOR_en-us CreateAdminImage succeeded!
2010/9/29:13:43:51 danielj KE41 Deployment INVENTOR_en-us Finalize succeeded!
2010/9/29:13:44:40 danielj KE41 Deployment ACM CreateTransform failed!
2 Failures - Same error message, however appears for a different reason each time..
Any ideas?
Solved by DanielJohnston. Go to Solution.
Can you provide more details? Screen shots and the steps in your workflow are helpful.
When during the use of the Deployment Wizard does it quit? What errors are displayed on the screen?
What type of device is the Deployment being written to?
Have you rebooted before trying the Deployment Wizard?
It quits during the DVD 4 and installing Mechanical, with the error ' Deployment Failed. The system cannot open the device or file specified.'
The Deployment it being written to a Server, as we have done it before.
I have even now tried a different PC, which resulted in the same error message 'Deployment ACM CreateGPOMsi failed! '
I haven't got any screen shots, it would take 2hrs to get them and to the point again..
It successfully installs Inventor..
It is configured as a Standalone, with a few tweaks to the config of Inventor and Mehanical.
Service Pack 1, 2 and 3 are installed at the same time for Inventor, and it downloads and installs Update 2 for Mechanical.
I have successfully installed Simulation Suite 2010 previously.
This sounds like bad media. Although I am not sure which product, suite, or media type you are using here for AutoCAD Mechanical 2010. Start by copying the disks to the same folder on the hard drive. Copy over disk 1 with disk 2 and click OK to overwrite files. Continue until all disks are copied. Then run the Deployment Wizard from that location on the hard drive. You might download the installer from Subscription Center.
Solution is here it seems...
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13423039&linkID=9240897
