• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    Problems Installing Revit Architecture 2013
    1024 Views, 2 Replies
    04-26-2012 11:14 AM
    Anyone getting errors when they try to install?  I've downloaded the program repeatedly and get the same error everytime.
    Entry Point Not Found
    The procedure entry point
    ?GetBitmapFromModule@CtrlUtil@@YAPAVBitmap@Gdiplus@@PB_W
    OPAUHINSTANCE_@@@Z could not be located in the dynamic link
    library LiteHtml.dll
    Please use plain text.
    Employee
    Re: Problems Installing Revit Architecture 2013
    04-30-2012 07:32 AM in reply to: mboyer
    I would start by searching your system for copies of the LiteHtml.dll, it maybe there are copies in folders other than the Revit folders that are causing problems. If you find this DLL in folders other than the Revit folders try renaming it then installing Revit again.
    Similar to http://usa.autodesk.com/getdoc/id=TS1053448
    When searching your system for copies of this DLL make sure to search System and Hidden folders.
    Danny
    Danny Hubbard
    QA Analyst
    Member
    jfrost5
    07-12-2012 07:29 AM in reply to: mboyer
    Try checking C:\Windows\SysWOW64 for the litehtml.dll - if there is a copy there, move or rename it & try the install again.  I ran into this issue when installing AutoCAD 2013.  After moving the litehtml file, I got an error with another dll.  It was in the same SysWOW64 folder and had the same date as the litehtml.  I ended up moving all files that matched that date out of the SysWOW64 folder.  After doing that, I was able to successful install the product.
