Installation & Licensing
Active Member
hshdavidson
Message 1 of 2 (422 Views)
Problems Installing Revit Architecture 2012
422 Views, 1 Replies
01-28-2012 05:16 PM
I am a student trying install a DL student version of Revit on a WinXP64 machine.  It goes through the whole process but at the end tells me that it has failed to install. I tried the Autodesk knowledge base suggestion, to uninstall all Autodesk software and try again, to no avail.   In a previous thread it was suggested that I try uninstalling Visual C++ and then allow Revit to install it again.  No good.  Finally, a contributor suggested I modify the setup.ini file, but I don't know how to do this.
I've been able to successfully install AutoCAD and AutoCAD Architecture.
Can anyone help?
I've attached teh install log and setup.ini (changed the .ini to .txt to send it).
TravisNave
Message 2 of 2 (395 Views)
Re: Problems Installing Revit Architecture 2012
01-30-2012 07:53 AM in reply to: hshdavidson
Sorry for the delay.  I posted a follow-up to your issue here:
http://forums.autodesk.com/t5/Installation-Licensing/Autodesk-Installation-Problems/td-p/3307645/pag...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
