Installation & Licensing
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Problems Installing Revit Architectu re 2012
Options
- Highlight
- Email to a Friend
317 Views, 1 Replies
01-28-2012 05:16 PM
I am a student trying install a DL student version of Revit on a WinXP64 machine. It goes through the whole process but at the end tells me that it has failed to install. I tried the Autodesk knowledge base suggestion, to uninstall all Autodesk software and try again, to no avail. In a previous thread it was suggested that I try uninstalling Visual C++ and then allow Revit to install it again. No good. Finally, a contributor suggested I modify the setup.ini file, but I don't know how to do this.
I've been able to successfully install AutoCAD and AutoCAD Architecture.
Can anyone help?
I've attached teh install log and setup.ini (changed the .ini to .txt to send it).
Re: Problems Installing Revit Architectu re 2012
Options
- Highlight
- Email to a Friend
01-30-2012 07:53 AM in reply to:
hshdavidson
Sorry for the delay. I posted a follow-up to your issue here:
Travis Nave
My Expert Contributions to the Discussion Groups:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
