Installation & Licensing
Problems Exporting License from Viz 2005 in Vista
2 REPLIES 2
358 Views, 2 Replies
Hi to all,
I have Viz 2005 and moved it/the license a few months ago from my old windows xp PC to my new vista machine.
I have been having problems with the new machine so im sending it back, problem is I have gone to the portable license utility to export the license off the machine before I send the pc back and it says.....
Insufficient privileges to export the license, please log in as an administrator and try again..
Problem is my account does have administrator rights but it is not recognising them... I tried setting up a new user account with administrator rights again to see if that would work but get the same message...
Has anyone else encountered this problem with vista and Autodesk licenses..?
And does anyone know a way I can fix this/export my license file so I can send my computer back..?
Many Thanks in advance for you replies
BC
2 REPLIES 2
TravisNave
Right click the program and choose Run As Administrator. This should solve your Vista woes. Even as Administrator, you are not an Administrator on Vista. Very annoying.
Autodesk Forums:
great just the info i was looking for, i will try it over the weekend....
Thankyou
Administrator Productivity
