Installation & Licensing
Problem with licensing (empty window)
3 REPLIES 3
1814 Views, 3 Replies
I have a problem with licensing. I has installed a inventor professional. When I lunch It, it's shows a licensing window, after pressing "activate" button it shows a white window. So I don't have a request code, which is needed to performing a licensing.
3 REPLIES 3
arlinpega.bibat
Hi megadeth6:
You may follow the steps provided through this link:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Arlin Bibat
TravisNave
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
