• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Problem with licensing (empty window)
    473 Views, 3 Replies
    05-20-2012 05:37 AM
    I have a problem with licensing. I has installed a inventor professional. When I lunch It, it's shows a licensing window, after pressing "activate" button it shows a white window. So I don't have a request code, which is needed to performing a licensing.
    Please use plain text.
    Customer Service
    arlinpega.bibat
    Re: Problem with licensing (empty window)
    05-20-2012 05:04 PM in reply to: megadeth6
    Hi megadeth6:
    You may follow the steps provided through this link:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
    Arlin Bibat
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    TravisNave
    05-21-2012 07:42 AM in reply to: megadeth6
    Additional discussion about this issue can be found here:
    http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    05-21-2012 08:54 AM in reply to: megadeth6
