I have a problem, I installed AutoCAD 2011 and when I run the program it says we enter the computer name of the license server system ... I looked at the website and I found something that says to run setup (as I understand it) and go on what install titles and one more thing ... But the problem is not that we run setup. I do not know what to do, and it is very urgent as I needed in the near future and I would be grateful if someone could help on this issue
Thanks in advance.
It sounds like you installed the network licensed version of AutoCAD. If you have a stand-alone license, then you need to reinstall. If you do, in fact, have a network version, then you need to install the Autodesk Network License Manager and obtain a license file from Autodesk.
