Installation & Licensing
Problem with installation of Autodesk 3d max
2 REPLIES 2
490 Views, 2 Replies
Hi people, sorry for my poor English but I wonder if they can solve my problem.
When I finish installing the 3dmax get an error that says "Installation complete. Some products failed to install". I already down 3 times and install it and the problem continues ...
Well I wish I could help with this, then let the error details. Thank you.
2013/3/19:20:48:32    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:20:48:32    Win7    WIN7-PC    Launch
2013/3/19:20:48:40    Win7    WIN7-PC    === Setup ended ===
2013/3/19:20:48:35    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:20:48:35    Win7    WIN7-PC    Launch
2013/3/19:20:48:40    Win7    WIN7-PC    PageOpen    LaunchDialog
2013/3/19:20:48:42    Win7    WIN7-PC    PageOpen    LicenseDialog
2013/3/19:20:48:45    Win7    WIN7-PC    PageOpen    ProductInfoDialog
2013/3/19:20:49:38    Win7    WIN7-PC    PageOpen    ProductSelectionDialog2
2013/3/19:20:49:43    Win7    WIN7-PC    PageOpen    FullProgressDialog
2013/3/19:20:50:06    Win7    WIN7-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/19:20:52:38    Win7    WIN7-PC    Install    DirectX® Runtime    Succeeded
2013/3/19:20:52:38    Win7    WIN7-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:20:53:18    Win7    WIN7-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/19:20:53:18    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:20:53:31    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/19:20:53:31    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:20:54:52    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/19:20:54:53    Win7    WIN7-PC    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\Win7\AppData\Local\Temp\_AI795.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:20:55:10    Win7    WIN7-PC    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1603
2013/3/19:20:55:29    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/19:20:55:48    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/19:20:56:14    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/19:20:56:14    Win7    WIN7-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/3/19:20:56:16    Win7    WIN7-PC    PageOpen    InstallCompleteDialog
2013/3/19:21:01:50    Win7    WIN7-PC    === Setup ended ===
2013/3/19:21:01:54    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:21:01:54    Win7    WIN7-PC    Launch
2013/3/19:21:01:59    Win7    WIN7-PC    === Setup ended ===
2013/3/19:21:01:56    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:21:01:56    Win7    WIN7-PC    Launch
2013/3/19:21:01:58    Win7    WIN7-PC    PageOpen    LaunchDialog
2013/3/19:21:02:03    Win7    WIN7-PC    PageOpen    LicenseDialog
2013/3/19:21:02:07    Win7    WIN7-PC    PageOpen    ProductInfoDialog
2013/3/19:21:02:27    Win7    WIN7-PC    PageOpen    ProductSelectionDialog2
2013/3/19:21:02:35    Win7    WIN7-PC    PageOpen    FullProgressDialog
2013/3/19:21:02:35    Win7    WIN7-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/19:21:04:18    Win7    WIN7-PC    Install    DirectX® Runtime    Succeeded
2013/3/19:21:04:18    Win7    WIN7-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:04:38    Win7    WIN7-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/19:21:04:38    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:05:01    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/19:21:05:01    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:06:15    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/19:21:06:17    Win7    WIN7-PC    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\Win7\AppData\Local\Temp\_AI458F.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:06:29    Win7    WIN7-PC    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1603
2013/3/19:21:06:43    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/19:21:06:58    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/19:21:07:16    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/19:21:07:16    Win7    WIN7-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/3/19:21:07:18    Win7    WIN7-PC    PageOpen    InstallCompleteDialog
2013/3/19:21:08:25    Win7    WIN7-PC    === Setup ended ===
2013/3/19:21:13:48    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:21:13:48    Win7    WIN7-PC    Launch
2013/3/19:21:13:52    Win7    WIN7-PC    === Setup ended ===
2013/3/19:21:13:50    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:21:13:50    Win7    WIN7-PC    Launch
2013/3/19:21:13:52    Win7    WIN7-PC    PageOpen    LaunchDialog
2013/3/19:21:13:55    Win7    WIN7-PC    PageOpen    LicenseDialog
2013/3/19:21:13:57    Win7    WIN7-PC    PageOpen    ProductInfoDialog
2013/3/19:21:14:19    Win7    WIN7-PC    PageOpen    ProductSelectionDialog2
2013/3/19:21:26:32    Win7    WIN7-PC    PageOpen    FullProgressDialog
2013/3/19:21:26:32    Win7    WIN7-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/19:21:28:38    Win7    WIN7-PC    Install    DirectX® Runtime    Succeeded
2013/3/19:21:28:38    Win7    WIN7-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:28:50    Win7    WIN7-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/19:21:28:50    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:29:03    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/19:21:29:03    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:30:09    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/19:21:30:10    Win7    WIN7-PC    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\Win7\AppData\Local\Temp\_AI2968.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:30:21    Win7    WIN7-PC    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1603
2013/3/19:21:30:32    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/19:21:30:46    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/19:21:31:04    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/19:21:31:04    Win7    WIN7-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/3/19:21:31:06    Win7    WIN7-PC    PageOpen    InstallCompleteDialog
2013/3/19:21:38:31    Win7    WIN7-PC    === Setup ended ===
2013/3/19:21:38:37    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:21:38:37    Win7    WIN7-PC    Launch
2013/3/19:21:38:41    Win7    WIN7-PC    === Setup ended ===
2013/3/19:21:38:39    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:21:38:39    Win7    WIN7-PC    Launch
2013/3/19:21:38:41    Win7    WIN7-PC    PageOpen    LaunchDialog
2013/3/19:21:38:43    Win7    WIN7-PC    PageOpen    LicenseDialog
2013/3/19:21:38:46    Win7    WIN7-PC    PageOpen    ProductInfoDialog
2013/3/19:21:39:07    Win7    WIN7-PC    PageOpen    ProductSelectionDialog2
2013/3/19:21:39:10    Win7    WIN7-PC    PageOpen    FullProgressDialog
2013/3/19:21:39:10    Win7    WIN7-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/19:21:40:26    Win7    WIN7-PC    Install    DirectX® Runtime    Succeeded
2013/3/19:21:40:26    Win7    WIN7-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:40:40    Win7    WIN7-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/19:21:40:40    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:41:16    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/19:21:41:16    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:42:22    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/19:21:42:24    Win7    WIN7-PC    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\Win7\AppData\Local\Temp\_AIE1CE.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:42:36    Win7    WIN7-PC    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1603
2013/3/19:21:42:49    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/19:21:43:03    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/19:21:43:22    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/19:21:43:22    Win7    WIN7-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/3/19:21:43:23    Win7    WIN7-PC    PageOpen    InstallCompleteDialog
2013/3/19:21:58:42    Win7    WIN7-PC    === Setup ended ===
2013/3/19:22:06:19    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:22:06:19    Win7    WIN7-PC    Launch
2013/3/19:22:06:19    Win7    WIN7-PC    CommandLine
2013/3/19:22:06:28    Win7    WIN7-PC    === Setup ended ===
2013/3/19:22:06:34    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:22:06:34    Win7    WIN7-PC    Launch
2013/3/19:22:06:34    Win7    WIN7-PC    CommandLine
2013/3/19:22:06:42    Win7    WIN7-PC    === Setup ended ===
2013/3/19:22:06:35    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:22:06:35    Win7    WIN7-PC    Launch
2013/3/19:22:06:43    Win7    WIN7-PC    === Setup ended ===
2013/3/19:22:06:57    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:22:06:57    Win7    WIN7-PC    Launch
2013/3/19:22:07:03    Win7    WIN7-PC    === Setup ended ===
2013/3/19:22:06:58    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/19:22:06:58    Win7    WIN7-PC    Launch
2013/3/19:22:07:03    Win7    WIN7-PC    PageOpen    LaunchDialog
2013/3/19:22:07:11    Win7    WIN7-PC    PageOpen    LicenseDialog
2013/3/19:22:07:14    Win7    WIN7-PC    PageOpen    ProductInfoDialog
2013/3/19:22:07:37    Win7    WIN7-PC    PageOpen    ProductSelectionDialog2
2013/3/19:22:07:42    Win7    WIN7-PC    PageOpen    FullProgressDialog
2013/3/19:22:10:19    Win7    WIN7-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/19:22:12:14    Win7    WIN7-PC    Install    DirectX® Runtime    Succeeded
2013/3/19:22:12:14    Win7    WIN7-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:22:12:36    Win7    WIN7-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/19:22:12:36    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:22:13:13    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/19:22:13:13    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:22:14:28    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/19:22:14:29    Win7    WIN7-PC    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\Win7\AppData\Local\Temp\_AIFB7D.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:22:14:43    Win7    WIN7-PC    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1603
2013/3/19:22:14:55    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/19:22:15:09    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/19:22:15:27    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/19:22:15:27    Win7    WIN7-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/3/19:22:15:28    Win7    WIN7-PC    PageOpen    InstallCompleteDialog
2013/3/19:22:16:50    Win7    WIN7-PC    === Setup ended ===
2013/3/20:21:03:36    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/20:21:03:36    Win7    WIN7-PC    Launch
2013/3/20:21:03:44    Win7    WIN7-PC    === Setup ended ===
2013/3/20:21:03:39    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/20:21:03:39    Win7    WIN7-PC    Launch
2013/3/20:21:03:44    Win7    WIN7-PC    PageOpen    LaunchDialog
2013/3/20:21:03:50    Win7    WIN7-PC    PageOpen    LicenseDialog
2013/3/20:21:03:52    Win7    WIN7-PC    PageOpen    ProductInfoDialog
2013/3/20:21:07:12    Win7    WIN7-PC    PageOpen    ProductSelectionDialog2
2013/3/20:21:07:17    Win7    WIN7-PC    PageOpen    FullProgressDialog
2013/3/20:21:07:17    Win7    WIN7-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/20:21:08:59    Win7    WIN7-PC    Install    DirectX® Runtime    Succeeded
2013/3/20:21:08:59    Win7    WIN7-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:09:14    Win7    WIN7-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/20:21:09:14    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:10:07    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/20:21:10:07    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:11:33    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/20:21:11:35    Win7    WIN7-PC    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\Win7\AppData\Local\Temp\_AI956A.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:11:48    Win7    WIN7-PC    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1603
2013/3/20:21:12:02    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/20:21:12:31    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/20:21:13:09    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/20:21:13:09    Win7    WIN7-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/3/20:21:13:10    Win7    WIN7-PC    PageOpen    InstallCompleteDialog
2013/3/20:21:13:28    Win7    WIN7-PC    === Setup ended ===
2013/3/20:21:15:55    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/20:21:15:55    Win7    WIN7-PC    Launch
2013/3/20:21:16:03    Win7    WIN7-PC    === Setup ended ===
2013/3/20:21:15:58    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/20:21:15:58    Win7    WIN7-PC    Launch
2013/3/20:21:16:03    Win7    WIN7-PC    PageOpen    LaunchDialog
2013/3/20:21:17:15    Win7    WIN7-PC    PageOpen    BeginDeploymentDialog
2013/3/20:21:17:18    Win7    WIN7-PC    PageOpen    LaunchDialog
2013/3/20:21:17:22    Win7    WIN7-PC    PageOpen    LicenseDialog
2013/3/20:21:17:25    Win7    WIN7-PC    PageOpen    ProductInfoDialog
2013/3/20:21:17:46    Win7    WIN7-PC    PageOpen    ProductSelectionDialog2
2013/3/20:21:27:42    Win7    WIN7-PC    PageOpen    FullProgressDialog
2013/3/20:21:27:42    Win7    WIN7-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/20:21:29:20    Win7    WIN7-PC    Install    DirectX® Runtime    Succeeded
2013/3/20:21:29:20    Win7    WIN7-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:29:41    Win7    WIN7-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/20:21:29:41    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:30:14    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/20:21:30:14    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:31:25    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/20:21:31:32    Win7    WIN7-PC    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\Win7\AppData\Local\Temp\_AIDBFB.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:31:45    Win7    WIN7-PC    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1603
2013/3/20:21:31:59    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/20:21:32:12    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/20:21:32:48    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/20:21:32:48    Win7    WIN7-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/3/20:21:32:49    Win7    WIN7-PC    PageOpen    InstallCompleteDialog
2013/3/20:21:41:36    Win7    WIN7-PC    === Setup ended ===
2013/3/20:21:45:14    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/20:21:45:14    Win7    WIN7-PC    Launch
2013/3/20:21:45:19    Win7    WIN7-PC    === Setup ended ===
2013/3/20:21:45:16    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/20:21:45:16    Win7    WIN7-PC    Launch
2013/3/20:21:45:19    Win7    WIN7-PC    PageOpen    LaunchDialog
2013/3/20:21:45:20    Win7    WIN7-PC    PageOpen    LicenseDialog
2013/3/20:21:45:33    Win7    WIN7-PC    PageOpen    ProductInfoDialog
2013/3/20:21:45:47    Win7    WIN7-PC    PageOpen    ProductSelectionDialog2
2013/3/20:21:45:50    Win7    WIN7-PC    PageOpen    FullProgressDialog
2013/3/20:21:45:51    Win7    WIN7-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/3/20:21:46:01    Win7    WIN7-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Succeeded
2013/3/20:21:46:01    Win7    WIN7-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/20:21:47:33    Win7    WIN7-PC    Install    DirectX® Runtime    Succeeded
2013/3/20:21:47:33    Win7    WIN7-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:48:17    Win7    WIN7-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/20:21:48:17    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:48:36    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/20:21:48:36    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:49:47    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/20:21:49:50    Win7    WIN7-PC    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\Win7\AppData\Local\Temp\_AIB2AB.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:50:03    Win7    WIN7-PC    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1603
2013/3/20:21:50:16    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/20:21:50:41    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/20:21:51:16    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/20:21:51:16    Win7    WIN7-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/3/20:21:51:16    Win7    WIN7-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Failed    Installation aborted, Result=1619
2013/3/20:21:51:18    Win7    WIN7-PC    PageOpen    InstallCompleteDialog
2013/3/20:21:52:45    Win7    WIN7-PC    === Setup ended ===
2013/3/20:21:54:07    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/20:21:54:07    Win7    WIN7-PC    Launch
2013/3/20:21:54:13    Win7    WIN7-PC    === Setup ended ===
2013/3/20:21:54:11    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/20:21:54:11    Win7    WIN7-PC    Launch
2013/3/20:21:54:12    Win7    WIN7-PC    PageOpen    LaunchDialog
2013/3/20:21:54:14    Win7    WIN7-PC    PageOpen    LicenseDialog
2013/3/20:21:54:15    Win7    WIN7-PC    PageOpen    ProductInfoDialog
2013/3/20:21:54:39    Win7    WIN7-PC    PageOpen    ProductSelectionDialog2
2013/3/20:21:54:47    Win7    WIN7-PC    PageOpen    FullProgressDialog
2013/3/20:21:54:47    Win7    WIN7-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/3/20:21:54:56    Win7    WIN7-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2013/3/20:21:54:56    Win7    WIN7-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/3/20:21:55:07    Win7    WIN7-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Succeeded
2013/3/20:21:55:07    Win7    WIN7-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/20:21:56:45    Win7    WIN7-PC    Install    DirectX® Runtime    Succeeded
2013/3/20:21:56:45    Win7    WIN7-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:57:00    Win7    WIN7-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/20:21:57:00    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:57:34    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/20:21:57:34    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:58:58    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/20:21:58:59    Win7    WIN7-PC    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\Win7\AppData\Local\Temp\_AID815.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:21:59:14    Win7    WIN7-PC    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1603
2013/3/20:21:59:26    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/20:21:59:46    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/20:22:00:23    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/20:22:00:23    Win7    WIN7-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/3/20:22:00:23    Win7    WIN7-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Failed    Installation aborted, Result=1619
2013/3/20:22:00:23    Win7    WIN7-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
2013/3/20:22:00:25    Win7    WIN7-PC    PageOpen    InstallCompleteDialog
2013/3/20:22:01:18    Win7    WIN7-PC    === Setup ended ===
2013/3/20:22:07:24    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/20:22:07:24    Win7    WIN7-PC    Launch
2013/3/20:22:07:29    Win7    WIN7-PC    === Setup ended ===
2013/3/20:22:07:26    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/3/20:22:07:26    Win7    WIN7-PC    Launch
2013/3/20:22:07:29    Win7    WIN7-PC    PageOpen    LaunchDialog
2013/3/20:22:07:32    Win7    WIN7-PC    PageOpen    LicenseDialog
2013/3/20:22:07:35    Win7    WIN7-PC    PageOpen    ProductInfoDialog
2013/3/20:22:07:56    Win7    WIN7-PC    PageOpen    ProductSelectionDialog2
2013/3/20:22:12:04    Win7    WIN7-PC    PageOpen    FullProgressDialog
2013/3/20:22:12:04    Win7    WIN7-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/3/20:22:12:12    Win7    WIN7-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2013/3/20:22:12:12    Win7    WIN7-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/3/20:22:12:22    Win7    WIN7-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Succeeded
2013/3/20:22:12:22    Win7    WIN7-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/20:22:13:55    Win7    WIN7-PC    Install    DirectX® Runtime    Succeeded
2013/3/20:22:13:55    Win7    WIN7-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:22:14:10    Win7    WIN7-PC    Install    Autodesk Material Library 2013    Succeeded
2013/3/20:22:14:10    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:22:14:53    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/20:22:14:53    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:22:16:17    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/20:22:16:20    Win7    WIN7-PC    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\Win7\AppData\Local\Temp\_AIF9.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/20:22:16:33    Win7    WIN7-PC    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1603
2013/3/20:22:16:48    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/3/20:22:17:08    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/3/20:22:17:45    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/3/20:22:17:46    Win7    WIN7-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/3/20:22:17:46    Win7    WIN7-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Failed    Installation aborted, Result=1619
2013/3/20:22:17:46    Win7    WIN7-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
2013/3/20:22:17:47    Win7    WIN7-PC    PageOpen    InstallCompleteDialog
2013/3/20:22:26:51    Win7    WIN7-PC    === Setup ended ===
2013/4/9:14:15:08    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/4/9:14:15:08    Win7    WIN7-PC    Launch
2013/4/9:14:15:11    Win7    WIN7-PC    === Setup ended ===
2013/4/9:14:15:09    Win7    WIN7-PC    === Setup started on WIN7-PC by Win7 ===
2013/4/9:14:15:09    Win7    WIN7-PC    Launch
2013/4/9:14:15:12    Win7    WIN7-PC    PageOpen    LaunchDialog
2013/4/9:14:15:14    Win7    WIN7-PC    PageOpen    LicenseDialog
2013/4/9:14:15:16    Win7    WIN7-PC    PageOpen    ProductInfoDialog
2013/4/9:14:15:51    Win7    WIN7-PC    PageOpen    ProductSelectionDialog2
2013/4/9:14:16:02    Win7    WIN7-PC    PageOpen    FullProgressDialog
2013/4/9:14:16:20    Win7    WIN7-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/4/9:14:16:36    Win7    WIN7-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2013/4/9:14:16:36    Win7    WIN7-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/4/9:14:16:46    Win7    WIN7-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Succeeded
2013/4/9:14:16:46    Win7    WIN7-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/9:14:18:28    Win7    WIN7-PC    Install    DirectX® Runtime    Succeeded
2013/4/9:14:18:28    Win7    WIN7-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/9:14:18:42    Win7    WIN7-PC    Install    Autodesk Material Library 2013    Succeeded
2013/4/9:14:18:42    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/9:14:19:20    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/4/9:14:19:20    Win7    WIN7-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/9:14:20:07    Win7    WIN7-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/4/9:14:20:10    Win7    WIN7-PC    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\Win7\AppData\Local\Temp\_AIAAB0.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/9:14:20:22    Win7    WIN7-PC    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1603
2013/4/9:14:20:40    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/4/9:14:20:54    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/4/9:14:21:12    Win7    WIN7-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/4/9:14:21:12    Win7    WIN7-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/4/9:14:21:12    Win7    WIN7-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Failed    Installation aborted, Result=1619
2013/4/9:14:21:13    Win7    WIN7-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
Tags (2)
2 REPLIES 2
PLEASE HELP ME!!! I NEED THIS PROGRAM FOR UNIVERSITY
TravisNave
Unfortunately there doesn't seem to be a particular reason for the failure.  You might have to look up different 1603 errors.
For additional information, please consider using Search to assist in your resolution:
Search Autodesk.com
Search Autodesk Discussion Groups
Search Up and Ready Blog
Search Autodesk WikiHelp
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
