Installation & Licensing
Problem with installation more then one product on my computer
1 REPLY 1
pmaslow115
525 Views, 1 Reply
Hi !
I'm new here. I hope that I'm writing in right place. I have problem with installaion Inventor and CFD Simulation 2014.
First of all I would like to note that I changed Windows 8.0 to 8.1. I had Inventor and CFD Simulation 2013 on it and everything worked very good.
I'll tried to explain my problem.
When I installed Inventor first everything was working. But I need to make solid and transfer it to CFD Simulation. That is why I  installed fter Inventor ,CFD. During installation I had problem because installation window was frezzing. I was waiting several times 10-30 minutes because I though that might be unfrezz but It was not work. I restarted computer and I installed cfd second time. Sometimes cfd was installed sometimes not. After that restat Inventor also didn't work. I tried to start Inventor but it was not work . I unistalled all of Autodesk and made it several times from the begining.
I also tried to instal CFD and Inventor Fusion but when I did it CFD worked Fusion not. I need those programs to make a solid like I said ealier but Inventor was the best for me.
I tried also back to win 8 and installed inventor and cfd 2013 but it was not work too.
I also installed service pack 1 to inventor and make solved my problem with NetFramework (IGNORE_FAILURE=YES).
I hope that I explained what my problem is. I need help asap because I need to work on this programs on my university.
Greetings
Paul
1 REPLY 1
pmaslow115
in reply to: pmaslow115
I don't know If someone has the same problem but I have found solution. I installed first cfd second inventor and next uninstalled cfd and installed cfd and it started work.
Administrator Productivity
