Hello
I have a problem with activation autodesk Autodesk 3ds Max 2012 64-bit
the problem is that:
When I clicked on "Activate" and next "Continue" the next screen was "Processing Error"
Your online activation request has returned an error (400) which is not allowing your request to be processed using our automated systems. |
Click the "Use another method" link below to complete the necessary forms and submit your request to the local Autodesk Business Center for your area. A Customer Service Representative will respond within the next 2 business days.
I have a student license
Solved by jessica.t. Go to Solution.
Hi Seb83670 & mariaperezsanz,
Welcome to the Community!
Could you please send me a Private Message (click on my grace.liu profile name and then “Send this user a private message”) with your Serial Number,Product Key, Request Code and your registration details , I will generate the activation code manually.
Or please contact our License Assistance Team for direct support.
Hello, i have the problem with activation AutoCad Mep 2014 for students, error 400, please help me.
Hello ivanzagulin and welcome to our forum! 🙂
Could you please send me a Private Message (click on my grace.liu profile name and then “Send this user a private message”) with your Serial Number,Product Key, Request Code and your registration details , I will help to activate it manually.
Hi
I have problem with activation autodesk Autocad 2011 64bit!
When i clicked on activate the next screen said that "windows stop to activate this program "
I think that there is no problem with the windows cause i can try this programm for 30 days without consequenses!
I dont know what to do if someone can help me i would apreciate that! My product key is 001C1
Hi iasonaspetch,
By the way, may I know the version of your operating system?
Hello, i have a problem with AutoCad 2011 activation (error 400). Could anyone help me with this? Thanks in advance.
i have a problem (error 400) with activation autocad 2014 32bit.. students license.. help please
Hello 258243 & dinamozagreb, welcome to our forum!
Got the same problem. I have sudent license and haven't activated it. Now there's this error 400 and i can't activate it. Help?
Hello Tukasz and welcome to the Autodesk Community!
If you could please send me your serial number and request code via private message I would be happy to assist you in generating an activation code.
Or for direct assistance please contact our Licensing Assistance team.
Thank you!
Hi! I had the same problem. I have the educational version of AutoCad 2013 and I can not activate it.
Can someone help me?
Thanks!
Hi Jhaber,
I will manually generate the Activation Code. Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and Request Code.
For reference, you can click here for any Activation assistance needed.
Hi! I had the same problem. I have the educational version of AutoCad 2012 and I can not activate it.
Thanks!
AutoCAD 2014
001F1
please help me I downloaded the student version of AutoCAD 2014 was 3 weeks actif jeans, send me an e mail thank my sahingeldec@hotmail.co
Hello Sahin,
We would be happy to assist you with your activation issue however first I would suggest that you delete your licensing information from this public forum as that is sensitive information.
But with that information I was able to generate an activation code that has been emailed to you.
If you have any other questions or concerns please respond to this post.
Thank you!
Hell Michal,
Apologies for your activation troubles. Please contact the Licensing Assistance team with your serial number, full product name, and request code so that they can generate an activation code for you.
If you have any other questions please reply to this post.
Thanks!
I have also problem with activation free 3-year students version Autocad Architecture 2012.
This error I have.
Can anyone help me?
Thanks!
Hello Majkel!
As the error 400 requires an manual activation code be generated, your best and fastest bet for obtaining one and the corresponding resolution would be to contact our License Assistance Team.
Here to help if you have any further questions!
